I hope you mean "Device is now functioning as expected."
After you reboot, do you see the parameter setting controls appear in the "parent" driver? They should.
Sorry, typo for me as well! It's fully functional.
Yes, I do see the parameter setting controls but haven't actually tried them as there hadn't been a need yet.
I also enabled the "Show Parameter Value Input Controls" feature and parameters through 14 do show up. However, parameters 1 and 3-6 do not, although there are blank, unlabeled placeholders where they should be. Parameter 8 has a glitch, that is, it says both:
"Input 2 calibration
Input 12 calibration"
the latter line being correct.
One day, I will learn to type more carefully.
Try again and let me know if it appears correct now . . .
Yup, that did it! I can't see anything that doesn't look or work perfectly now.
Thanks again for this.
