Just got my HE in the mail, trying to set evertying up, but having some issues with the connection between google home and hubitat.
when linking, hubitat can't seem to detect, 2 lamps, chromecast or my Xiaomi vacuum.
Did try to follow the documentation guide, but when it comes to the ''Autohorize google home API to access your hubitat Device'' part, i see no devices.
I am pretty green on all of this home automation stuff, but i wanna learn!
if it helps or tells anyone any thing, i cant seem to detect any of my Sonos speakers trough the sonos integration app aswell.
I don't have this specific Google Home problem but I've read, here, repeatedly, that maybe the Hub Registration went awry. Send an Email to Support@Hubitat.com and wait to be amazed at the response time.
The other way is to tag staff directly: @bobbyD but of course you take the risk that the tagged person is away, (illness or holiday or..)
As to advice... well I'd start with the Hubitat videos.
It helps to see the UI in action because it often looks static and you can't see a button someone describes.. only to find the page is dynamic and changes as you add things.
It sounds like you have those devices already connected to your Google Home...is that correct? If so, Hubitat cannot detect those devices via the Google Home integration. It is designed to work the other way around. Devices paired with your Hubitat Hub can be discovered and controlled via your Google Home device.
