I'm new to home automation and HE. I'm not sure if this is the right forum to post this in.
Does anyone know if a window air conditional unit on the market will work with a HE?
I don't know if the ones marked as wifi enabled and compatible with Google/Alexa will work with HE. Thanks,
SS
There are at least a couple ways to integrate a window air conditioner with Hubitat. Both of them involve purchasing a window unit that has an IR (infrared) remote (most units do).
In the first method, you could use a Remotec z-wave/IR extender (ZXT-120) to control the window unit. There is a built-in driver for the ZXT-120.
In the second method, you can get a Broadlink IR device (like the RM mini3) to control the window unit. There is a community integration by @cybrmage for Broadlink devices.
I like this theme
In the third method, you can buy a cheep analog unit, plug it into a smart plug, set it on high (set it and forget it!) Now you have air conditioner on/off control via plug/HE. Proof of concept ![:laughing: :laughing:](https://community.hubitat.com/images/emoji/apple/laughing.png?v=9)
In the forth method, you could use one of those WiFi units with ifttt but they will not talk to HE directly. I have not done this, only theory.
And welcome to HE!
