I upgraded to the latest release and overall like the improvements in the interface. Today I went to modify one of my Easy Dashboards, and after adding some more devices, I clicked the “Update dashboard” button, and it doesn’t update. If I close the page, it says, “Closing without updating dashboard?” Seems like this might be a bug.
Can't reproduce from either dashboards page or dashboard itself.
If you hit F12 in Chrome and check Javascript console, does it show any errors?
I’m trying on my iPad. Tried on two different iPads with the same result. I’ll try on a MacBook and see if I get the same results.
I updated to 2.4.0.143 and now it is working as expected. Thank you.
Correction: I was editing an Easy Dashboard that did not have HSM and was able to update/save the changes. However, if you have HSM selected for the Easy Dashboard, HE is requiring a PIN. If you don’t enter a PIN, you can’t “Update dashboard”. If you disable HSM, then you can “Update dashboard”. Seems like the bug is the requirement of a PIN whether you want one or not.
To be fixed in the next build.
