HDFury VRRoom IP Commands
Hi! Is there a way to build an app/driver for the HDFury VRRoom/Diva devices or leverage something already made? They can be controlled by IP commands that are provided.
VRRoom Info: https://hdfury.com/product/8k-vrroom-40gbps/
VRRoom Manual: https://www.hdfury.com/docs/HDfuryVRRoom.pdf
IP Command Listing: https://pastebin.com/kkm7deue
Following
I will probably need this solution by the end of the year.
As OP mentioned, it looks like it can accept commands over an IP network, from the manual that would be with a Telnet connection.
So yes it's should be possible to integrate with Hubitat. Someone would need to write a driver for it.
Thanks @marktheknife. Hopefully someone with the skills to write drivers will buy one of these and create a driver.
