Don't see the setting for the AA tabs either. Surprisingly the stated CarAPI is 1. Neither 5 nor 6 or do I have to connect to AA first?
@jpage4500 Just checked the latest version in the car.
- I love the updated icon. It looks awesome, thanks!
Regarding the CarAPI and the setting for the Android Auto tab. Both appears/gets updated after connecting to AA.
CarAPI 6.
Unfortunately HD+ crashes badly if tabs are turned on and can't be started again until AA is disconnected.
Please let me know if you would like to see some log files.
Joe
Sure, if there's something useful in there I'll try to fix it.
Do you have or know of any other AA app that has the tab layout?
I did ask if Google could add an example of it in their 'samples' code, just in case there's something I'm missing. I can't see what though..
I'm also not sure what that "available only on AA for Early Access Partners.." means.. maybe it's just not implemented for everyone yet even if you have API6?
The option to view the tabs in HD+ settings won't even show up unless you have already connected to a car that's running API6. I didn't want to show a tabbed layout in the UI but then not show it in the car since it's not supported.
Technically, you can make it show up in the settings if you enable debug mode in the app - but the car still won't show it without API6 though
Tested 1.0.1991 Did not try tabs. My 2017 VW AllTrack's Infotainment system with AA is likely outdated and has never been updated. The dealer claims there are no updates available.
On the AA screen the HSM icon accurately reflects the status of HSM and changes when the HD+ phone screen changes.
The AA HSM button says Arm/Disarm being sent, but it does not arm or disarm the HE system. Arm/Disarm works from the HD+ phone screen.
The HD+ screen does not update to Armed (mode) after showing an Armed (mode) Delay. I use a 30 second delay. However, after reloading HD+ it reflects the correct mode that is then correctly reflected on the AA screen.
The garage door worked as expected from AA
Suggestion:
On the AA HSM icon show the arming state instead of the icon name text 'HSM (Arm/Disar..'
thanks for the feedback! I haven't had a chance to test much in an actual car yet.. just don't get to drive in my wife's car very often but I'll try to make time.
If you or anyone else is willing to send me logs I'll look through them. The key is to make sure you enable debug mode in HD+ which captures some of the more important details. Then, if you click on about -> support it'll let you send the logs via email or some other route.
Log follows the armAway command of interest is
| 05/12 13:55:22 | I | HubitatManager | sendCommand: armAway to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 13:55:22 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:55:22 | D | CustomInterceptor | 148) GET http://192.168.0.106/apps/api/6593/devices/ID_HSM/armAway |
| 05/12 13:55:22 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:55:22 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:55:22 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:55:22 | E | CustomInterceptor | HTTP_ERROR: 148) http:404 66ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/armAway, RESP:null |
| 05/12 13:55:22 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 13:55:22 | D | AutoHomeScreen | onDeviceUpdatedEvent: ID_HSM |
Entire Log
Summary
| 05/06 11:36:09 | I | MainApplication | APP START: v:1.0.1984, MODEL:moto x4, OS:9, SDK:28 |
| 05/06 11:36:09 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 11:36:15 | I | LoginFragment | discoverHub: found HUB: 192.168.0.106, http://192.168.0.106:80/api/hubitat.xml |
| 05/06 11:36:16 | I | HubitatManager | login: IP:192.168.0.106, appId:6593, Access Token:true, Cloud Token:true |
| 05/06 11:36:16 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:false, SSID:null, TOKEN:true |
| 05/06 11:37:03 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/06 11:37:22 | I | HubitatManager | sendCommand: close to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:closed} |
| 05/06 11:37:28 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 11:37 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683387443201,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 11:37:33 | W | HubitatManager | handleMessage: failed to update: retry:2, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:1,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 11:37 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683387443201,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 11:37:38 | W | HubitatManager | handleMessage: failed to update: retry:3, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:2,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 11:37 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683387443201,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 11:37:43 | W | HubitatManager | handleMessage: failed to update: retry:4, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:3,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 11:37 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683387443201,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 12:24:42 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 12:24:43 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 12:24:43 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 12:24:51 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 12:24:52 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 12:26:09 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/06 12:26:22 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 12:26:23 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 12:26:31 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 12:26:32 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 12:26:32 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 12:26:58 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:887.7k, TOTAL:9M, MAX:384M |
| 05/06 12:27:00 | I | HubitatManager | sendCommand: close to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:closed} |
| 05/06 12:27:06 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 12:23 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683390421295,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 12:27:11 | W | HubitatManager | handleMessage: failed to update: retry:2, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:1,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 12:23 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683390421295,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 12:27:16 | W | HubitatManager | handleMessage: failed to update: retry:3, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:2,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 12:23 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683390421295,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 12:27:21 | W | HubitatManager | handleMessage: failed to update: retry:4, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:3,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 12:23 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683390421295,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 12:27:25 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/06 12:27:26 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:opening,doorSensor:Garage Door Multi is closed,myQDeviceId:CG0830120277,contact:closed,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 12:27 PM,CloseButton:normal,battery:100,switch:off},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683390445759,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 12:27:38 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.1M, TOTAL:12.7M, MAX:384M |
| 05/06 12:28:55 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.8M, TOTAL:12.7M, MAX:384M |
| 05/06 12:29:29 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.8M, TOTAL:12.7M, MAX:384M |
| 05/06 12:30:47 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.3M, TOTAL:12.7M, MAX:384M |
| 05/06 12:31:50 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.3M, TOTAL:12.7M, MAX:384M |
| 05/06 12:32:03 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.3M, TOTAL:12.7M, MAX:384M |
| 05/06 12:33:09 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/06 12:33:14 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:opening,doorSensor:Garage Door Multi is closed,myQDeviceId:CG0830120277,contact:closed,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 12:33 PM,CloseButton:normal,battery:100,switch:off},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683390789806,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 14:00:02 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/06 14:00:04 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/06 14:00:09 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/06 14:21:23 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/06 14:21:25 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/06 14:25:58 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 14:29:33 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1M, TOTAL:9.3M, MAX:384M |
| 05/06 14:29:35 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1M, TOTAL:9.3M, MAX:384M |
| 05/06 14:29:37 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1M, TOTAL:9.3M, MAX:384M |
| 05/06 14:32:39 | I | HubitatManager | sendCommand: disarm to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/06 14:32:39 | E | CustomInterceptor | HTTP_ERROR: 135) http:404 140ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/disarm, RESP:null |
| 05/06 14:32:39 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/06 14:33:21 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 14:33:22 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 14:33:41 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 14:33:42 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 14:34:15 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 14:34:16 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 14:34:17 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.2M, TOTAL:18.6M, MAX:384M |
| 05/06 14:34:23 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 14:34:23 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/06 14:34:24 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 14:34:29 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 14:34:30 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 14:34:39 | I | HubitatManager | sendCommand: disarm to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/06 14:34:39 | E | CustomInterceptor | HTTP_ERROR: 190) http:404 31ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/disarm, RESP:null |
| 05/06 14:34:39 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/06 14:34:50 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/06 14:34:50 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 14:34:51 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 14:34:54 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 14:34:55 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 14:35:37 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.3M, TOTAL:16.9M, MAX:384M |
| 05/06 14:36:00 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/06 14:36:38 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/06 14:36:46 | I | HubitatManager | sendCommand: close to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:closed} |
| 05/06 14:36:51 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 02:36 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683398206578,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 14:36:56 | W | HubitatManager | handleMessage: failed to update: retry:2, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:1,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 02:36 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683398206578,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 14:37:01 | W | HubitatManager | handleMessage: failed to update: retry:3, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:2,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 02:36 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683398206578,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 14:37:06 | W | HubitatManager | handleMessage: failed to update: retry:4, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:3,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/6/2023 02:36 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683398206578,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/06 14:42:20 | E | NetworkUtils | downloadUrlToString: onFailure: failed to connect to /192.168.0.106 (port 80) from /192.168.0.32 (port 44019) after 15000ms, url:http://192.168.0.106/hub/cloud/checkForUpdate |
| 05/06 14:42:36 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.4M, TOTAL:15.4M, MAX:384M |
| 05/06 14:46:45 | I | MainApplication | APP START: v:1.0.1984, MODEL:moto x4, OS:9, SDK:28 |
| 05/06 14:46:46 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.6M, TOTAL:4.4M, MAX:384M |
| 05/06 14:46:46 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 14:46:46 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/06 14:48:30 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:971.2k, TOTAL:8.5M, MAX:384M |
| 05/06 18:15:45 | I | MainApplication | APP START: v:1.0.1984, MODEL:moto x4, OS:9, SDK:28 |
| 05/06 18:15:45 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:65k, TOTAL:3.6M, MAX:384M |
| 05/06 18:15:45 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/06 18:15:45 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/06 18:17:10 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/06 18:17:24 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/07 11:14:47 | I | MainApplication | APP START: v:1.0.1984, MODEL:moto x4, OS:9, SDK:28 |
| 05/07 11:14:47 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/07 11:14:47 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/07 11:14:48 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.3M, TOTAL:4.3M, MAX:384M |
| 05/07 11:14:50 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.2M, TOTAL:4.3M, MAX:384M |
| 05/07 11:15:27 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:2M, TOTAL:4.5M, MAX:384M |
| 05/07 11:15:28 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:2M, TOTAL:4.5M, MAX:384M |
| 05/07 11:19:31 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/07 11:19:47 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/07 11:21:09 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/07 11:21:10 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/07 11:21:33 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:2M, TOTAL:4.8M, MAX:384M |
| 05/07 11:21:44 | I | HubitatManager | sendCommand: disarm to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/07 11:21:44 | E | CustomInterceptor | HTTP_ERROR: 243) http:404 200ms https://cloud.hubitat.com/api/688b7aec-d880-4820-b764-f9b5840081c7/apps/6593/devices/ID_HSM/disarm, RESP:null |
| 05/07 11:21:44 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/07 11:22:34 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/07 18:37:45 | I | MainApplication | APP START: v:1.0.1984, MODEL:moto x4, OS:9, SDK:28 |
| 05/07 18:37:46 | I | MainReceiver | handleBootCompleted: |
| 05/07 18:37:46 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/08 20:59:12 | I | MainApplication | APP START: v:1.0.1987, MODEL:moto x4, OS:9, SDK:28 |
| 05/08 20:59:12 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/08 20:59:12 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/08 21:14:50 | I | MainApplication | APP START: v:1.0.1987, MODEL:moto x4, OS:9, SDK:28 |
| 05/08 21:14:50 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/08 21:14:50 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/08 21:15:45 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/08 21:16:02 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/08 21:16:03 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/09 17:03:25 | I | MainApplication | APP START: v:1.0.1987, MODEL:moto x4, OS:9, SDK:28 |
| 05/09 17:03:25 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/09 17:03:26 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/09 17:03:38 | I | HubitatManager | sendCommand: close to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:closed} |
| 05/09 17:03:44 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/9/2023 05:01 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683666219469,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/09 17:03:49 | W | HubitatManager | handleMessage: failed to update: retry:2, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:1,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/9/2023 05:01 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683666219469,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/09 17:03:54 | W | HubitatManager | handleMessage: failed to update: retry:3, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:2,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/9/2023 05:01 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683666219469,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/09 17:03:59 | W | HubitatManager | handleMessage: failed to update: retry:4, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:3,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/9/2023 05:01 PM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683666219469,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/09 17:04:53 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/09 17:04:59 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:opening,doorSensor:Garage Door Multi is closed,myQDeviceId:CG0830120277,contact:closed,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/9/2023 05:04 PM,CloseButton:normal,battery:100,switch:off},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683666294403,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/10 00:45:41 | I | MainApplication | APP START: v:1.0.1987, MODEL:moto x4, OS:9, SDK:28 |
| 05/10 00:45:41 | I | MainReceiver | handleBootCompleted: |
| 05/10 00:45:41 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/10 09:41:24 | I | MainApplication | APP START: v:1.0.1987, MODEL:moto x4, OS:9, SDK:28 |
| 05/10 09:41:24 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/10 09:41:24 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/11 00:40:35 | I | MainApplication | APP START: v:1.0.1991, MODEL:moto x4, OS:9, SDK:28 |
| 05/11 00:40:35 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/11 00:40:35 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/12 09:50:53 | I | MainApplication | APP START: v:1.0.1991, MODEL:moto x4, OS:9, SDK:28 |
| 05/12 09:50:53 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 09:50:54 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/12 09:51:15 | I | HubitatManager | sendCommand: armAway to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 09:51:15 | E | CustomInterceptor | HTTP_ERROR: 15) http:404 98ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/armAway, RESP:null |
| 05/12 09:51:15 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 09:51:48 | I | HubitatManager | sendCommand: armAway to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 09:51:48 | E | CustomInterceptor | HTTP_ERROR: 25) http:404 102ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/armAway, RESP:null |
| 05/12 09:51:48 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 09:52:01 | I | HubitatManager | sendCommand: open to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:open} |
| 05/12 09:52:07 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:opening,doorSensor:Garage Door Multi is closed,myQDeviceId:CG0830120277,contact:closed,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/12/2023 09:50 AM,CloseButton:normal,battery:100,switch:off},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683899522202,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/12 09:52:17 | I | HubitatManager | sendCommand: close to device: Door (ID:2242), type:TYPE_GARAGE, updating:{door:closed} |
| 05/12 09:52:23 | W | HubitatManager | handleMessage: failed to update: retry:1, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/12/2023 09:52 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683899538477,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/12 09:52:28 | W | HubitatManager | handleMessage: failed to update: retry:2, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:1,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/12/2023 09:52 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683899538477,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/12 09:52:33 | W | HubitatManager | handleMessage: failed to update: retry:3, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:2,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/12/2023 09:52 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683899538477,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/12 09:52:38 | W | HubitatManager | handleMessage: failed to update: retry:4, {attributes:{door:closing,doorSensor:Garage Door Multi is open,myQDeviceId:CG0830120277,retryCount:3,contact:open,myQAccountId:8c31bebd-8124-4877-a3ed-86728f5a24ed,OpenButton:normal,lastActivity:05/12/2023 09:52 AM,CloseButton:normal,battery:100,switch:on},capabilities:[Actuator,Refresh,Battery,DoorControl,Polling,ContactSensor,GarageDoorControl,Switch,Momentary,Sensor],commands:[close,off,on,open,poll,push,refresh,updateDeviceLastActivity,updateDeviceMoving,updateDeviceStatus,updateMyQDeviceId,updateSensorBattery],id:2242,label:Door,lastUpdateTime:1683899538477,name:Door,room:Garage,type:MyQ Garage Door Opener} |
| 05/12 09:52:59 | I | HubitatManager | sendCommand: disarm to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 09:52:59 | E | CustomInterceptor | HTTP_ERROR: 58) http:404 62ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/disarm, RESP:null |
| 05/12 09:52:59 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 09:54:47 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.4M, TOTAL:9.4M, MAX:384M |
| 05/12 09:55:07 | I | HubitatManager | sendCommand: disarm to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 09:55:07 | E | CustomInterceptor | HTTP_ERROR: 71) http:404 60ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/disarm, RESP:null |
| 05/12 09:55:07 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 09:57:27 | I | HubitatManager | sendCommand: disarm to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 09:57:27 | E | CustomInterceptor | HTTP_ERROR: 92) http:404 60ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/disarm, RESP:null |
| 05/12 09:57:27 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 12:37:05 | I | MainApplication | APP START: v:1.0.1991, MODEL:moto x4, OS:9, SDK:28 |
| 05/12 12:37:05 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 12:37:06 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/12 12:37:47 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:3.4M, TOTAL:8.2M, MAX:384M |
| 05/12 12:39:01 | I | HubitatManager | sendCommand: disarm to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 12:39:01 | E | CustomInterceptor | HTTP_ERROR: 32) http:404 55ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/disarm, RESP:null |
| 05/12 12:39:01 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 12:39:52 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.4M, TOTAL:11.5M, MAX:384M |
| 05/12 12:40:44 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.1M, TOTAL:11.5M, MAX:384M |
| 05/12 12:40:50 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 12:40:51 | I | MainReceiver | handleConnectivityAction: ONLINE, MOBILE |
| 05/12 12:40:53 | I | HubitatManager | checkCloudMode: MODE_AUTO, CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 12:40:58 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.7M, TOTAL:11.5M, MAX:384M |
| 05/12 12:41:00 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.5M, TOTAL:11.5M, MAX:384M |
| 05/12 12:41:11 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:6.3M, TOTAL:13M, MAX:384M |
| 05/12 12:41:25 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.5M, TOTAL:13M, MAX:384M |
| 05/12 12:42:35 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:3.9M, TOTAL:13M, MAX:384M |
| 05/12 12:45:01 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.3M, TOTAL:6M, MAX:384M |
| 05/12 12:46:46 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.1M, TOTAL:6M, MAX:384M |
| 05/12 12:46:52 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.1M, TOTAL:6M, MAX:384M |
| 05/12 12:50:28 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/12 12:53:49 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 12:53:50 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 12:53:51 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 12:54:02 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 12:54:08 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 12:54:08 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 12:57:56 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/12 12:59:27 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 12:59:28 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:21:22 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 13:24:21 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 13:24:22 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:24:22 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 13:24:33 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:28:55 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 13:34:00 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 13:34:01 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:34:04 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 13:37:26 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 13:37:27 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:37:30 | I | MainReceiver | handleConnectivityAction: ONLINE, WIFI |
| 05/12 13:37:31 | I | HubitatManager | checkCloudMode: MODE_AUTO, LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:38:09 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 13:38:10 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:41:59 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 13:42:21 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 13:42:21 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:42:25 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 13:48:57 | I | MainReceiver | handleConnectivityAction: OFFLINE, |
| 05/12 13:48:57 | I | MainReceiver | handleConnectivityAction: OFFLINE, MOBILE |
| 05/12 13:49:01 | I | MainReceiver | handleConnectivityAction: OFFLINE, WIFI |
| 05/12 13:53:01 | I | Utils | setDebugMode: true |
| 05/12 13:53:13 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:53:13 | D | DashboardConfig | setGridSize: itemHeight:296, cols:6, offset:0 (screen:1776x1080) |
| 05/12 13:53:13 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:53:13 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:53:13 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:53:13 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:53:56 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:53:56 | D | DashboardConfig | setGridSize: itemHeight:360, cols:3, offset:0 (screen:1080x1776) |
| 05/12 13:53:56 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:53:56 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:53:56 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:53:56 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:54:09 | D | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_LOW: FREE:2.4M, TOTAL:12.5M, MAX:384M |
| 05/12 13:54:10 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:54:10 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:54:10 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:54:10 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:54:14 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:54:14 | D | DashboardConfig | setGridSize: itemHeight:360, cols:3, offset:0 (screen:1080x1776) |
| 05/12 13:54:15 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:54:15 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:54:15 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:54:15 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:54:16 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:6.4M, TOTAL:13.4M, MAX:384M |
| 05/12 13:54:30 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:6.3M, TOTAL:13.4M, MAX:384M |
| 05/12 13:54:44 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:6.3M, TOTAL:13.4M, MAX:384M |
| 05/12 13:54:53 | D | AutoService | onCreateSession: |
| 05/12 13:54:53 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:54:53 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:54:53 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:54:53 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:54:53 | D | AutoHomeScreen | onGetTemplate: API:5, GRID_LIMIT:100, devices:2 |
| 05/12 13:55:05 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.5M, TOTAL:13.4M, MAX:384M |
| 05/12 13:55:08 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.4M, TOTAL:13.4M, MAX:384M |
| 05/12 13:55:15 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:55:15 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:55:15 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:55:15 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:55:17 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.2M, TOTAL:13.4M, MAX:384M |
| 05/12 13:55:19 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:55:19 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:55:19 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:55:19 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:55:24 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:4.3M, TOTAL:13.4M, MAX:384M |
| 05/12 13:55:50 | D | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_LOW: FREE:1.3M, TOTAL:13.4M, MAX:384M |
| 05/12 13:55:53 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.2M, TOTAL:13.4M, MAX:384M |
| 05/12 13:56:00 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:994.7k, TOTAL:13.4M, MAX:384M |
| 05/12 13:56:01 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:962.7k, TOTAL:13.4M, MAX:384M |
| 05/12 13:56:02 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:946.7k, TOTAL:13.4M, MAX:384M |
| 05/12 13:56:13 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:56:13 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:56:13 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:56:13 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:56:15 | I | HubitatManager | sendCommand: armAway to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 13:56:15 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:56:15 | D | CustomInterceptor | 158) GET http://192.168.0.106/apps/api/6593/devices/ID_HSM/armAway |
| 05/12 13:56:15 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:56:15 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:56:15 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:56:15 | E | CustomInterceptor | HTTP_ERROR: 158) http:404 95ms http://192.168.0.106/apps/api/6593/devices/ID_HSM/armAway, RESP:null |
| 05/12 13:56:15 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 13:56:15 | D | AutoHomeScreen | onDeviceUpdatedEvent: ID_HSM |
| 05/12 13:56:42 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:56:43 | D | DashboardConfig | setGridSize: itemHeight:360, cols:3, offset:0 (screen:1080x1776) |
| 05/12 13:56:43 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:56:43 | D | AutoService | onDestroy: |
| 05/12 13:56:43 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:56:43 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:56:43 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:56:55 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:56:55 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:56:55 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:56:55 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:56:58 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:56:58 | D | DashboardConfig | setGridSize: itemHeight:360, cols:3, offset:0 (screen:1080x1776) |
| 05/12 13:56:58 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:56:58 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:56:58 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:56:58 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:57:13 | D | AutoService | onCreateSession: |
| 05/12 13:57:13 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:57:13 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:57:13 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:57:13 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:57:14 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:6.4M, TOTAL:13.6M, MAX:384M |
| 05/12 13:57:52 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:57:52 | D | DashboardConfig | setGridSize: itemHeight:360, cols:3, offset:0 (screen:1080x1776) |
| 05/12 13:57:53 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:57:53 | D | AutoService | onDestroy: |
| 05/12 13:57:53 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:57:53 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:57:53 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:57:59 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:1.4M, TOTAL:13.6M, MAX:384M |
| 05/12 13:58:04 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:58:04 | D | DashboardConfig | setGridSize: itemHeight:296, cols:6, offset:0 (screen:1776x1080) |
| 05/12 13:58:04 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:58:04 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:58:04 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:58:04 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:58:19 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:7.7M, TOTAL:16.5M, MAX:384M |
| 05/12 13:58:24 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:7.6M, TOTAL:16.5M, MAX:384M |
| 05/12 13:58:34 | D | DashboardFragment | onCreateView: isConfigChanged:true, popupDeviceId:null |
| 05/12 13:58:34 | D | DashboardConfig | setGridSize: itemHeight:360, cols:3, offset:0 (screen:1080x1776) |
| 05/12 13:58:34 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:58:34 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:58:34 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:58:34 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:59:32 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:59:32 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:59:32 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:59:32 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:59:34 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:59:34 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:59:34 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:59:34 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:59:56 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:59:56 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:59:56 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:59:56 | D | HubitatManager | syncDevices: full:false |
| 05/12 13:59:58 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 13:59:58 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 13:59:58 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 13:59:58 | D | HubitatManager | syncDevices: full:false |
| 05/12 14:00:42 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 14:00:42 | D | HubitatManager | checkCloudMode: currentSSID:[Have a nice day2 :-)5gz] |
| 05/12 14:00:42 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: LOCAL: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 14:00:42 | D | HubitatManager | syncDevices: full:false |
| 05/12 14:01:18 | I | Utils | setDebugMode: false |
| 05/12 14:02:33 | I | DebugHelper | DEVICES:4, SIZE:1.7k |
| 05/12 14:02:33 | I | DebugHelper | MODEL:moto x4, OS:9, SDK:28 |
| 05/12 14:02:33 | I | DebugHelper | IP:192.168.0.106, APP_ID:6593, HAS_TOKEN:true |
| 05/12 14:02:37 | I | MainApplication | onTrimMemory: TRIM_MEMORY_RUNNING_CRITICAL: FREE:5.6M, TOTAL:14.7M, MAX:384M |
thanks for the logs! It looks like the app thinks you're on the local network and not in cloud mode. I'm assuming you're really outside of your home (unless you're in the garage lol)
Right after sending the command the app checks local/cloud and decides it's still local so that doesn't help either.
I imagine what's happening is the app itself isn't 'running' fully in the background when AA is displayed. Or, it's getting paused and when the command is sent it doesn't fully wait until the app is ready. I can probably assume the majority of android auto commands will need to go the remote/cloud route so I can factor that in
(side-note - not sure if you can attach the file instead of pasting but I typically use another app to review/filter logs that's easier)
I assume the phone was on my local Orbi mesh Wifi network while parked in the driveway. As I mentioned the garage door open/close command worked as expected on Wifi.
I would tend to disarm the HSM system while pulling into the driveway where the phone could be either the phone provider's network or my local wifi.
I was unable to figure out how to attach the file on the forum, txt files are not accepted. I could do it with an email, but could not find your email address.
About to turn off the phone's wifi, then retry the arming command while on AA with the phone provider's network.
The following actions were performed while on phone provider's network, phone wifi off.
HSM Arming/Disarming on AA screen fails, works from phone's HD+ app screen.
Garage door open/close works as expected.
Debug for armAway command follows. Will send entire file if needed when I get an email address or figure out how to do it on the forum. Also noticed two other files that will also be sent if needed.
| 05/12 16:23:25 | I | HubitatManager | sendCommand: armAway to device: HSM (Arm/Disarm) (ID:ID_HSM), type:TYPE_HSM, updating:null |
| 05/12 16:23:25 | D | CustomInterceptor | 175) GET https://cloud.hubitat.com/api/****/apps/6593/devices/ID_HSM/armAway |
| 05/12 16:23:25 | D | HubitatManager | handleResume: isFirstSync:false |
| 05/12 16:23:25 | D | HubitatManager | checkCloudMode: LOCAL_NETWORK_NOT_CONNECTED |
| 05/12 16:23:25 | D | HubitatManager | checkCloudMode: MODE_AUTO, NO CHANGE: CLOUD: hasPermission:true, SSID:Have a nice day2 :-)5gz, TOKEN:true |
| 05/12 16:23:25 | D | HubitatManager | syncDevices: full:false |
| 05/12 16:23:25 | E | CustomInterceptor | HTTP_ERROR: 175) http:404 135ms https://cloud.hubitat.com/api/modified to protect my system/apps/6593/devices/ID_HSM/armAway, RESP:null |
| 05/12 16:23:25 | E | HubitatManager | onFailure: error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) |
| 05/12 16:23:25 | D | AutoHomeScreen | onDeviceUpdatedEvent: ID_HSM |
| error:RetrofitErrorEvent(errorCode=404, errorMessage=Device not found or not authorized) | |||
Update: turned off Wifi and armed system from HD+ phone screen
| 05/12 16:53:06 | D | HubitatManager | syncDevices: full:true |
| 05/12 16:53:07 | D | HubitatManager | fetchAllDevices: got:3 devices, total:4 |
| 05/12 16:53:08 | D | CustomInterceptor | 429) GET https://cloud.hubitat.com/api/****/apps/6593/hsm/armAway |
| 05/12 16:53:09 | D | CustomInterceptor | DONE: 429) 690ms https://cloud.hubitat.com/api/****/apps/6593/hsm/armAway |
| 05/12 16:53:12 | D | HubitatManager | syncDevices: full:true |
just a quick update - I pushed the latest version to production and it's live now. So, no need to run the beta version to have Android Auto support
I still haven't done much 'live' testing on this -- I just haven't been in my wife's car for a while.. I'll try to do it a little this weekend and will take notes/logs for anything that doesn't work or look great.
Feel free to throw out any suggestions as well. I'm sure there's several device types that I haven't supported yet but I can look at
Ive noticed if ibhavent opened the hd+ app on my phone for awhile and then connect to android auto the android auto app says i uave no devices authorized even though i do and should open the app on my phone to add devices.
When i open the app on my phone the devices immediately populate on android auto.
Is this the expected behavior?
Would it be possible to have HD+ automatically toggle a presence sensor based on whether the phone is plugged into Android auto?
Not expected, no. I will try to test this case this weekend when hopefully I get some time
Would this be instead of using the location / geofence feature? Or something else/unrelated?
Instead of. It'd be a way to let the hub know I'm in the car.
Similar for me. Not sure if it is caused by not opening the app on the phone, but I will get the no devices messages on Android Auto (AA). I get round it by moving to another AA app and then back to HD+ and all of my devices are there.
HTH
I was hoping to get some time to test AA last weekend - but that didn't work out.
If anyone is able to reproduce AA issues like this one and can send me device logs that would be helpful. I do need debug mode to be enabled beforehand since not much is logged otherwise.
I haven't used it much because I rarely plug my phone into the car. If I am not mistaken (someone correct me if I am wrong) but newer cars support bluetooth based Android Auto. Anyways I am working on a project using a rasberry pi type device to run my AA and just hotspot it to my phone. Than this app will be massively more useful to me.
It's only Bluetooth to setup a direct WiFi connection.
