I have copied the code for Harmony Hub into the drivers code section of the hub web interface and then plugged into Rule Machine what I want to happen when I turn my T.V. off. It seems to work but as I was looking at the logs I saw a lot of blue debug icons. Am I doing something wrong or just ignore it? I am very new to all of this. Thank you for any help that you can give.
Those are just debug statements that the creator of the harmony interface has in the code. They aren't errors or anything bad. You can ignore them or search through the code and take them out yourself, if they bother you that much.
They should turn themselves off after 30 minutes...IIRC.
