Harmony Hub Device Access
Does anybody write an app for Hubitat that lets you trigger individual devices in your setup? I've had this with a previous hub platform. I have IR extenders that I use from the hub location to several rooms. If for no other reason I don't what to shut down everything in every room with the OFF command. I don't want to use activities. The way it turns everything off with the off command and loses device state if the hand unit doesn't change things itself...is driving me crazy writing rules.
I basically never even touch the Logitech remote. I do everything via automation. I want direct access to each device which can be accessed from the remote...for a reason :upside_down_face:.
I
My Harmony Hub integration does allow one to issue Device Commands. You have to know the Harmony Hub device ID and associated command, so it takes a little work. Search the Harmony Hub thread for a detailed post as this question has come up a few times in the past. The information is in there.
Awesome...THANKS!
Just wanted to say thanks again and it was even easier than I thought! All I needed is already built into your amazing driver.
I may not use the handheld Harmony remote, but I do use my Apple TV remotes. The DeviceOn & DeviceOff were all I needed to solve all the problems I had (that and a Marantz driver for changing inputs. Other things scattered around my house I use Harmony for I just need on/off as well (without the pain of keeping up with how Harmony activities work).
Thanks Again...this is awesome!
