jmarte
March 18, 2020, 9:21pm
1
Hello,
Anybody can tell me how to integrate Harmony Companion into Hubitat?
I assume you have a harmony hub?
jmarte
March 18, 2020, 9:34pm
5
No, I have not
I am new using Hubitat
Iโm not sure if there are any others.. But this one came up quick in a search
And it looks to be actively maintained.. There was an update this month
jmarte
March 18, 2020, 9:55pm
7
I was thinking it was plug and play.
I do not know the installation step
Which part?..
Install of the code? or Setup after adding the code?
jmarte
March 18, 2020, 11:09pm
10
I have to do both.
where I have to go to download the code?
Welcome. This is just a driver. Bryan just posted the doc for Apps so you know how to do it in the future.
# Hubitat Logitech Harmony Hub Driver
It is used to communicate via webSockets to a Logitech Harmony Hub and it creates child devices for each Harmony Activity. Instant status updates are included as well! No polling necessary to keep Hubitat updated when a user changes the Activity via a Harmony Remote Control or the Harmony Mobile Phone App.
- v0.1.20181225 - Initial beta release
- v0.1.20181227 - Fixed Hub Restart Issue
- v0.1.20190104 - Faster Activity Switch Response Times
- v0.1.20190107 - Live Logging Tweak
- v0.1.20190220 - Fixed routine to obtain the remoteId due to firmware 4.15.250 changes by Logitech - Thanks @corerootedxb!
- v0.1.20190609 - Added importURL to definition
- v0.1.20190714 - Added Volume and Channel controls (for activities that support these features)- Thanks @aaron for the help!
- v0.1.20190715 - Added setLevel and setVolume commands to enable limited Dashboard support
- v0.1.20190723 - Added Actuator Capability to allow device to be used in RM's 'Custom Actions'
- v0.1.20191231 - Improved volume control logic, fixed small bug preventing volume updates if number of repeats was 0
- v0.1.20200114 - Added Switch Capability and Default Activity user preference. If the Parent switch is turned on, the default activity is turned on. If the Parent switch is turned off, the current Activity is turned off.
- v0.1.20200301 - Added Left, Right, Up, Down and OK commands along with custom command option - Requires the device ID - @rebecca (Rebecca Ellenby)
**Instructions For Use**
NOTE: You must be running Hubitat Elevation firmware version v2.0.3.114 or newer!
This file has been truncated. show original
Please follow the detailed instructions in my ReadMe. There are actually two drivers that youโll need.
- v0.1.20200918 - Added Home Control Buttons for Harmony remotes that support these buttons - Thanks @abuttino!
- v0.1.20200920 - Use 'pushed' and 'held' events for 'Home Control Buttons'
- v0.1.20201123 - Added custom level attributes for Home Control Buttons. Thanks @fabien.giuliano and @abuttino.
- v0.1.20201228 - Fixed Null division issue caused in the 11-23-2020 release
jmarte
March 19, 2020, 12:03am
13
In the Virtual Dive
in the Type list, I do not see: Logitech Harmony Hub Parent
User installed driver code is at the bottom of the list
You need to install not only the parent code
* File: Logitech-Harmony-Hub-Parent.groovy
* Platform: Hubitat
* https://raw.githubusercontent.com/ogiewon/Hubitat/master/Drivers/logitech-harmony-hub-parent.src/logitech-harmony-hub-parent.groovy
* Requirements:
* 1) Logitech Harmony Home Hub connected to same LAN as your Hubitat Hub. Use router
* DHCP Reservation to prevent IP address from changing.
* 2) HubDuino "Child Switch" Driver is also necessary. This is available
* at https://github.com/DanielOgorchock/ST_Anything/tree/master/HubDuino/Drivers
* Copyright 2018 Dan G Ogorchock
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
But also the child code
https://raw.githubusercontent.com/DanielOgorchock/ST_Anything/master/HubDuino/Drivers/child-switch.groovy
jmarte
March 19, 2020, 2:00am
15
Thanks all of you I did the installation of the driver
For those that have used this app.... What button templates did everyone use? I used the "Button" and it doesnt seem to work.
I believe this "Button" Template came from my MyQ integration and the options are ButtonOpen and ButtonClose...
As I type this I realize why those may not work, so any guidance would be appreciated.
@ogiewon
Still new to this thing, but I love it more and more each day and I GREATLY appreciate all the work the smart people are doing in making all these things work!
Just wanted to reply in case anyone else has similar questions....
I figured it out. It turns out that I just needed to use a "Switch" Template and this seems to do the trick.
system
Closed
September 22, 2022, 5:48pm
18
