Half my zwave devices have stopped working
This morning half my zwave devices have stopped working (Including all my S0 devices), I am trying to recover but they are now showing up as ghosts in my zwave table and I cant get my stick to even include o I can remove ghosts
Power cycle your hub. Use the Shutdown command in Settings and wait for the red LED. Then pull the power at the wall, because we always warn that the tiny microUSB socket can be delicate. You don't want to be testing your micro soldering skills today, I'm sure. :slight_smile:
Give the Hub 30 seconds to dissipate all the power inside and then plug in and check. A LOT of situations with these symptoms get cured by a full power cycle.
The power down appeared to have gotten rid of the stagnicity, but I think I must have had a zwave switch die. It and nearby devices are all misbehaving intermittently. I will replace the switch this afternoon.
Zwave is ill, I have posted another message with the symptoms I am seeing
