117C-2100-01000036 is LED2013G5 - E27 806lm WW Bulb. 'NEW' because of updated energy rating
On pairing it wrongly identified as an IKEA Tradfri Control Outlet (E1603) from @dandanache ikea device driver family. changed to Advanced Zigbee bulb, and all appears fine.
It was only because they had the cabinets unlocked as I bulk-bought the Valhorn Motion sensor (I wanted to test the consistency of the lux readings between sensors). Plus they had reduced the previous versions of bulbs to £/€3 each.
I needed a larger trolley
Now, if I could just get the last remaining 'new' GU10/LED2106R3 to pair...
Click & Collect, It's not just for large items anymore and no queueing Although I did get funny looks ordering only a 50p tea towel and a contact sensor
At my local IKEA (Leeds) you're lucky if you can park at the weekend. C&C is usually a separate building with it's own parking
The few times my wife and I went to IKEA, we either got lost trying to figure out the shortcuts or we got stuck behind a family of lollygaggers that walked slowly 5 abreast.
My hips and knees prefer Click and Collect.
I get charged $5.00 for the service but they give me a $5.00 coupon for next time.
I've been waiting to do this for a while, but it looks like one of my Tradfrei bulbs isn't supported.
I have four GU10's, and they were bought in two batches, I think the one that is giving me the issue was either the first, or the last bulb I purchased.
The other three report as:
after the update.
The buld that won't update was set to this User driver:
Changing the driver to Advanced CT Bulb, or just "Device" makes no difference.
According to the list and to your screenshots, the bulb is at its latest version (1.0.012), and no update is needed.
The message you get in the logs also confirms it: "Firmware update for ... is not available" means that the Hubitat hub does not a have newer firmware version to update to.
Just tried to update my E1810 remote(the "wheel") it never started,even tho the battery was 70% , I placed a new battery and rebooted the C7(because the memory drops 200kb within 30mins of reboot) and placed the remotw on top of the hub, and the update started.
I even tried to update it on Z2M, Z2M said no update available.
E1810 button is connected but nothing shows in the logs when buttons are pressed. Maybe it will work in button controller? I'll check it out as I've seen other buttons behave this way.
Nope no response even when button controller app setup.
Should I try to re-pair again?
Is there some magic trick to get the E1766 to update firmware? I have three and I can get "Starting firmware update...", but then it errors out. My last attempt I kept tapping the button to make sure it stayed awake hoping to see the "firmware update is 10% complete..." (this works great for the blinds) but no love. The blinds updated fine, but the buttons are not feeling it. Any advice?
EDIT: Must have just needed to post this in order for it to work. One last try and one of the E1766 is updating. Weird. I changed nothing.
It is total magic to me. I had better luck doing them from another room.
I am just happy to have the 9 hours of firmware updates done. All three blinds and all three buttons are now updated
EDIT: I think one problem was that some of the buttons were not properly paired. They worked fine, but did not show the full set of information in the Data section of device details. I repaired them a few times until the data fully populated. Then to update the firmware, I clicked “ok" to the firmware update within a second of pressing a button on the remote.
Hi @dandanache , if it's easy would it be possible to add a last updated column to the table at the top please, eg mm/yy It might make it easier for those that check now and again if there's an update
