Hey folks - brand new hubitat user here (coming from smartthings). Apologies if this is a blatantly obvious issue.
So my master bedroom has a total of 9 recessed lights (each with a smart bulb) and two lights outside the patio door. I have them set up as a group, and that works fantastic. Controlling them through the group works absolutely perfectly.
The problem comes when I try to control them using a scene. I have a scene set up called "master off" that just turns all the lights in the room off. If I activate the scene (directly through the UI, or via Alexa, or via a button action), it pretty consistently will fail to turn off at least two of them. Similarly, I have a scene called "Master Normal" (set the master bedroom to a "normal" on state) that suffers from the same issue - it (more often than not) will not get all of the lights activated.
Here's an example of the logs from a failed "master off" run - I was hoping somebody might have an idea of what's going on? (links removed because it wouldn't accept them)
[dev:33] 2020-11-19 22:51:43.733 [debug] parse description: catchall: 0104 0006 01 01 0040 00 0B44 00 00 0000 0B 01 0000
[dev:33] 2020-11-19 22:51:43.687 [debug] parse description: catchall: 0104 0006 01 01 0040 00 0B44 00 00 0000 0B 01 0000
[dev:37] 2020-11-19 22:51:42.393 [info] Master Bank 1 Light 2 was turned off
[dev:33] 2020-11-19 22:51:42.322 [debug] parse description: catchall: 0104 0006 01 01 0040 00 0B44 00 00 0000 0B 01 0000
[dev:40] 2020-11-19 22:51:41.782 [info] Master Bank 3 Light 2 was turned off
[dev:33] 2020-11-19 22:51:41.750 [info] Master Patio 2 is off
[dev:33] 2020-11-19 22:51:41.745 [debug] evt- rawValue:0, value: off, descT: Master Patio 2 is off
[dev:33] 2020-11-19 22:51:41.715 [debug] parse description: read attr - raw: 0B440100060A00001000, dni: 0B44, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
[dev:35] 2020-11-19 22:51:41.677 [info] Master Bank 1 Light 1 was turned off
[dev:33] 2020-11-19 22:51:40.772 [debug] parse description: catchall: 0104 0006 01 01 0040 00 0B44 00 00 0000 0B 01 0000
[dev:112] 2020-11-19 22:51:40.393 [info] Master Off was turned on
