Groovy Section statement, "Unexpected Error"
Placing a Groovy Section statement inside an iteration, such as each, always generates an error. Seems to destroy the iteration.
Source code
definition(
		namespace: "hubitat",
		author: "AAB",
		description: "test section",
		category: "Convenience",
		iconUrl: "",
		iconX2Url: ""
preferences {
    page(name: "mainPage")
def mainPage()
	dynamicPage(name: "mainPage", title: "Test Section", install: true, uninstall: true)
		section
			input "globalLights", "capability.switch", required: true, multiple: true, submitOnChange: true,
				title: "One or more Bulbs, Leds or Switches"
		if (globalLights)
			globalLights.each
				section ("${it.label}", hideable: true, hidden: true)
					input "global${it.id}Lux", "number", required: false, multiple: false, range: "1..8000",submitOnChange: true,
						title: "${it.label}<br />Lux On/Off point 1 to 8000. Leave blank to use Standard Lux settings (Optional)"
def installed() {
    initialize()
def updated() {
    initialize()
def initialize()
This will work if you explicitly name the closure parameter, so instead of:
globalLights.each { ... }
try:
globalLights.each { globalLight -> ... }
...using globalLight instead of it inside your closure.
My guess is that section itself is implemented as a closure, making the implicit it be null in that inner context, but I don't know enough about Hubitat's implementation or Groovy nuts-and-bolts to give you a good explanation here. :slight_smile:
Thank You!
That works.
