groovy.lang.MissingMethodException - HomeSeer Multi-Sensor HSM200
Hello all, I'm getting these error messages in my logs, seemingly at random.
dev:7692024-02-20 15:28:27.620errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
Possible solutions: getAt(java.lang.String), next(), putAt(java.lang.String, java.lang.Object), wait(), grep(), getClass() on line 449 (method parse)
dev:7692024-02-20 15:28:27.327errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:28:27.026errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:28:24.339errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:28:24.071errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:28:23.841errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:24:45.578infoNotification: Home Security
dev:7692024-02-20 15:22:07.706infoNotification: Home Security
dev:7692024-02-20 15:21:58.082errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:21:57.774errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:21:57.482errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:21:04.050errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:21:03.750errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:21:03.449errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:16:47.910errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:16:47.621errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
dev:7692024-02-20 15:16:47.307errorgroovy.lang.MissingMethodException: No signature of method: java.lang.Double.getAt() is applicable for argument types: (java.lang.Integer) values: [0]
Can anyone tell me what. they mean? It seems like the Hub is being overwhelmed here, but I don't know what to do about it.
What driver are you using? I’m using the EZmultiPli new driver and my logs are clear.
IMG_0759
