For any future searchers, I was never able to get this to work through rule machine. I ended up writing it in WebCoRe and then eventually re-did it in node-red using the lullaby node to get exactly what I wanted. Has worked flawless since.
I used a virtual switch so I can also trigger this on/off with double taps on the inovelli switch I have in the room. And yes I realize I've got 7:55am weekday and 7:55am weekend triggers. Normal weekday wakeup time is 7:05 but with Covid we've been enjoying the extra 50mins to sleep.
[{"id":"62e4313f.3b6c6","type":"afya-lullaby","z":"ff73ed77.2a157","name":"Dim over 45Mins","dimmingTime":"2700","startValue":100,"stopValue":"20","step":1,"x":530,"y":2500,"wires":[["be6d87b.46db578"]]},{"id":"be6d87b.46db578","type":"api-call-service","z":"ff73ed77.2a157","name":"Dim Light","server":"94fdcfdf.a00b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.night_light_bulb","data":"{\"brightness_pct\":\"{{payload.value}}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":720,"y":2500,"wires":[[]]},{"id":"4e163e4e.dbb0d","type":"afya-lullaby","z":"ff73ed77.2a157","name":"Ramp Up over 10Min","dimmingTime":"600","startValue":"20","stopValue":"100","step":1,"x":760,"y":2620,"wires":[["770eb666.85d6b8"]]},{"id":"770eb666.85d6b8","type":"api-call-service","z":"ff73ed77.2a157","name":"Ramp Up Light","server":"94fdcfdf.a00b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.night_light_bulb","data":"{\"brightness_pct\":\"{{payload.value}}\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":980,"y":2620,"wires":[[]]},{"id":"5d8b0c9.fbdccf4","type":"inject","z":"ff73ed77.2a157","name":"7:55am Weekday","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"55 07 * * 1,2,3,4,5","once":false,"onceDelay":0.1,"x":110,"y":2600,"wires":[["182a7c56.23aa84"]]},{"id":"73d75d31.e63514","type":"server-state-changed","z":"ff73ed77.2a157","name":"Night Light On?","server":"94fdcfdf.a00b","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"light.night_light","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":100,"y":2500,"wires":[["2501b371.0d0adc"],["5aeb99fb.bf9118"]]},{"id":"2d408ddb.ea48d2","type":"inject","z":"ff73ed77.2a157","name":"7:55am Weekend","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"55 07 * * 6,0","once":false,"onceDelay":0.1,"x":110,"y":2640,"wires":[["182a7c56.23aa84"]]},{"id":"ca201441.7f9878","type":"api-call-service","z":"ff73ed77.2a157","name":"Turn Off","server":"94fdcfdf.a00b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.night_light_bulb","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":500,"y":2560,"wires":[[]]},{"id":"9fc20f8e.ac9a9","type":"api-call-service","z":"ff73ed77.2a157","name":"Turn On Night Light","server":"94fdcfdf.a00b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.night_light","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":530,"y":2700,"wires":[[]]},{"id":"61b6e5da.f6959c","type":"inject","z":"ff73ed77.2a157","name":"7:15pm Turn On","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"15 19 * * *","once":false,"onceDelay":0.1,"x":110,"y":2720,"wires":[["172666cd.c34319"]]},{"id":"dccea50e.083428","type":"inject","z":"ff73ed77.2a157","name":"12:15pm Turn On","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"15 12 * * 6,0","once":false,"onceDelay":0.1,"x":110,"y":2680,"wires":[["172666cd.c34319"]]},{"id":"d77c0632.1914d8","type":"inject","z":"ff73ed77.2a157","name":"8:05am Turn Off","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"05 08 * * *","once":false,"onceDelay":0.1,"x":110,"y":2800,"wires":[["57c2692b.a330e8"]]},{"id":"57c2692b.a330e8","type":"api-call-service","z":"ff73ed77.2a157","name":"Turn Off Night Light","server":"94fdcfdf.a00b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_off","entityId":"light.night_light","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":330,"y":2780,"wires":[[]]},{"id":"2501b371.0d0adc","type":"api-call-service","z":"ff73ed77.2a157","name":"Set Color - Pink","server":"94fdcfdf.a00b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.night_light_bulb","data":"{\"color_name\":\"magenta\",\"brightness_pct\":100}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":320,"y":2500,"wires":[["62e4313f.3b6c6"]]},{"id":"a01d1f32.b6a81","type":"api-call-service","z":"ff73ed77.2a157","name":"Set Color - Green","server":"94fdcfdf.a00b","version":1,"debugenabled":false,"service_domain":"light","service":"turn_on","entityId":"light.night_light_bulb","data":"{\"color_name\":\"green\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":530,"y":2620,"wires":[["4e163e4e.dbb0d"]]},{"id":"3b4cf5fa.c2c89a","type":"inject","z":"ff73ed77.2a157","name":"3:00pm Turn Off","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"00 15 * * *","once":false,"onceDelay":0.1,"x":110,"y":2760,"wires":[["57c2692b.a330e8"]]},{"id":"172666cd.c34319","type":"api-current-state","z":"ff73ed77.2a157","name":"Are we home?","server":"94fdcfdf.a00b","version":1,"outputs":2,"halt_if":"Home - Morning, Home - Afternoon, Home - Evening, Home - Night, Babysitter","halt_if_type":"str","halt_if_compare":"includes","override_topic":false,"entity_id":"input_select.house_mode","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":320,"y":2700,"wires":[["9fc20f8e.ac9a9"],[]]},{"id":"5aeb99fb.bf9118","type":"unsafe-function","z":"ff73ed77.2a157","name":"Kill Timer","func":"msg.payload=\"kill\"\nreturn msg;","outputs":1,"noerr":0,"x":300,"y":2560,"wires":[["62e4313f.3b6c6","ca201441.7f9878","4e163e4e.dbb0d"]]},{"id":"182a7c56.23aa84","type":"api-current-state","z":"ff73ed77.2a157","name":"Are we home?","server":"94fdcfdf.a00b","version":1,"outputs":2,"halt_if":"Home - Morning, Home - Afternoon, Home - Evening, Home - Night, Babysitter","halt_if_type":"str","halt_if_compare":"includes","override_topic":false,"entity_id":"input_select.house_mode","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":320,"y":2620,"wires":[["a01d1f32.b6a81"],[]]},{"id":"94fdcfdf.a00b","type":"server","z":"","name":"Home Assistant","addon":true}]
