Govee HDMI 2.1 Sync Box supports matter
I think a found a reason to enable matter on my C7. Replacing a cloud device for one that can be controlled locally always gives me goose bumps and i hope Govee continues with the matter trend. :innocent:
https://www.amazon.com/dp/B0DDPSCLFR/?coliid=I9LZ3V35LONTL&colid=14SUK7Y8MZQJH&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it
As of late pretty much every new device they have released has supported Matter. They have a pretty good selection of devices that do.
The question is what does that support get you. It won't give you advanced functions, but will likely enable allot of the standard controls. My experience with the standard Matter Driver that is built into Hubitat was ok but not stellar because of something to do with transitions. Here is my Govee Matter Driver that I created to prevent that problem. It also allows you to use a flat file on the hub to activate scenes locally
Here is the list of current supported Matter devices as I have seen it
Matter Devices
Device Name Model Number(s) Device Type Driver Comment
Smart Plug Pro H5085 Plug Generic Matter Outlet
Table Lamp 2 H6022 Light Device Govee RGBW Matter
Wall Sconce H6039 Light Device Govee RGBW Matter
Govee Gaming Wall Light H6063 Light Device Govee RGBW Matter
Floor Lamp 2 H607C Light Device Govee RGBW Matter .
M1 Led Strip H61E0 Light Device Govee RGBW Matter
Govee Strip Light 2 Pro H61F2, H61F5, H61F6 Light Device Govee RGBW Matter
Neon Rope Light 2 H61D2-H61D5 Light Device Govee RGBW Matter
Govee Perm Outdoor Lights Pro Light Device Govee RGBW Matter
Govee Perm Outdoor Lights 2 Light Device Govee RGBW Matter
Neon Rope Light for Wall Lining H6640-H6641 Light Device Govee RGBW Matter .
Govee Christmas Tree Lights 2 H70C4-H70C5-H70C7-H70C9 Light Device Govee RGBW Matter
Govee Icicle Lights H70D1-H70D2 Light Device Govee RGBW Matter
Govee COB H61E5 Light Device Govee RGBW Matter
Starry Light Projector H6093 Light Device Govee RGBW Matter
Govee Outdoor Triad Flood Lights H7063 Light Device Govee RGBW Matter
Govee Outdoor Deck Lights H7067-H7069 Light Device Govee RGBW Matter
Outdoor Wall Light H7075 Light Device Govee RGBW Matter
Govee Curtain Lights 2 H70B5 Light Device Govee RGBW Matter
Govee Net Lights H6811 Light Device Govee RGBW Matter
Smart Tower Fan Max H7105 Fan Govee H7105 Fan(Matter) Does not support Govee Wind Modes
Govee AI Sync Box Kit H6603-H6604 TV Light Kit Govee RGBW Matter
If you get that device and add it with Matter then you send me the device cluster info i will check my Matter Documentation to see if there are any additional functions that I can add.
Honestly, all i want is to automate on/off of the leds according to rules i already have setup in RM. I’m hoping i wont need to adjust any other settings after i have it setup. My needs should be β€œbasic”,:crossed_fingers:t3:but i’ll defo check out your driver in case my brain decides to get all fancy on me.
I’m be sure to send it your way. :fist_right:t3:
