I have notice when setting a mode (or "scene" as GH calls it) via Google home assistant, it works correctly to hubitat but GH gives a response saying that it didn't work. I know there is a work around that we can use switches and RM but that doesn't fix the issue.
I'm not sure if it's HE or GH that is the issue but all the posts on this just give the solution of using a switch. @bobbyD is this a known issue or should it be reported to support?
