I have just rediscovered Google Home and have a question about the thermostat settings. I currently have three virtual thermostats that I use. One of them is for my hot water system. I generally keep it about 145 and bump it up sometimes. The thermostat in Google Home will only go up to 90. Is there any way to change that? Since it is a built in APP I cannot get to the code.
Unfortunately at this time no. Same applies for the reverse. If a refrigerator is added the minimum is 50 degrees.
Water heaters and refrigerators are new to Google home however and were added within the last couple months. I would assume that this will change in the future.
Thanks for the info. Someday then ...
Merry Christmas!
