I’m trying to connect Hubitat to my Google Home. Anyone know how to debug issues on this? It says it linked and then immediately gives an error. I never get to select my hub.
Check that your hubitat hub shows in the hubitat portal. Also make sure you're not doing any type of blocking via your router, firewalls etc.
You did install the Google home app in hubitat apps section, correct?
I can't install the google home app inside of Hubitat. All it does is direct me to this doc link which says it will be automatically installed once I link (which I can't get it to do).
