Google Home integrations
I have been all over the forums and I have seen similar issues but nothing that solves my issue. I noticed my google home app integrations was partially working, and I needed to add some new devices so I went to sync and I got the message from the google home app: "Could not reach Hubitat, please try again". After this I went to the hubitat and took a look at the logs and I see this:
app:7062024-11-25 11:47:16.029 AMerrorsyncResponse Error: {
"error": {
"code": 404,
"message": "Requested entity was not found.",
"status": "NOT_FOUND"
, giving up for now
app:7062024-11-25 11:47:05.994 AMerrorsyncResponse Error: {
"error": {
"code": 404,
, giving up for now
app:7062024-11-25 11:46:36.367 AMwarnunknownError: java.lang.IllegalArgumentException: Text must not be null or empty
app:7062024-11-25 11:46:34.177 AMinfoupdated...
app:7062024-11-25 11:46:19.143 AMwarnunknownError: java.lang.IllegalArgumentException: Text must not be null or empty
app:7062024-11-25 11:46:16.660 AMinfoupdated...
I was originally running a c-5 I did also upgrade to the c-8 pro and still the same issue after migrating to the new hub.
I removed the integrations from google and now I am unable to reconnect at all. Other than adding a few hue bulbs there hasn't been any recent changes to the hubitat, and both hubs are up to date.
can you Enable debug logging in the app options then re-add the device in question then post the live logs?
There is something about the device that the integration doesn't like.
Sorry I did that too and it didn't help me very much.
app:7062024-11-25 12:51:30.369 PMerrorsyncResponse Error: { "error": { "code": 404, "message": "Requested entity was not found.", "status": "NOT_FOUND" } } , giving up for now
app:7062024-11-25 12:51:20.340 PMerrorsyncResponse Error: { "error": { "code": 404, "message": "Requested entity was not found.", "status": "NOT_FOUND" } } , giving up for now
app:7062024-11-25 12:50:51.217 PMwarnunknownError: java.lang.IllegalArgumentException: Text must not be null or empty
app:7062024-11-25 12:50:51.215 PMdebuggetDeviceAttributes trait:FanSpeed
app:7062024-11-25 12:50:51.213 PMdebuggetDeviceAttributes trait:OnOff
app:7062024-11-25 12:50:51.211 PMdebuggetDeviceAttributes device:Family Room Ceiling Fan, deviceType:[name:Fan, type:FAN, specificCaps:[Fan Control], traits:[OnOff, FanSpeed], heAttributes:[speed]]
app:7062024-11-25 12:50:51.209 PMdebuggetDeviceType final:[name:Fan, type:FAN, specificCaps:[Fan Control], traits:[OnOff, FanSpeed], heAttributes:[speed]]
app:7062024-11-25 12:50:51.207 PMdebuggetDeviceType intermediate:[speed]
app:7062024-11-25 12:50:51.205 PMdebuggetDeviceType added:speed
app:7062024-11-25 12:50:51.203 PMdebuggetDeviceType added:switch
app:7062024-11-25 12:50:51.201 PMdebuggetDeviceType added:level
app:7062024-11-25 12:50:51.198 PMdebuggetDeviceType device:Family Room Ceiling Fan, attributes:[level, supportedFanSpeeds, switch, speed]
app:7062024-11-25 12:50:51.196 PMdebuggetDeviceAttributes final:[:]
app:7062024-11-25 12:50:51.194 PMdebuggetDeviceAttributes trait:LockUnlock
app:7062024-11-25 12:50:51.192 PMdebuggetDeviceAttributes device:FrontDoorLock, deviceType:[name:Lock, type:LOCK, specificCaps:[Lock], traits:[LockUnlock], heAttributes:[lock]]
app:7062024-11-25 12:50:51.189 PMdebuggetDeviceType final:[name:Lock, type:LOCK, specificCaps:[Lock], traits:[LockUnlock], heAttributes:[lock]]
app:7062024-11-25 12:50:51.184 PMdebuggetDeviceType intermediate:[lock]
app:7062024-11-25 12:50:51.182 PMdebuggetDeviceType added:lock
app:7062024-11-25 12:50:51.180 PMdebuggetDeviceType device:FrontDoorLock, attributes:[codeLength, maxCodes, lockCodes, battery, codeChanged, lastCodeName, lock]
app:7062024-11-25 12:50:51.178 PMdebuggetDeviceAttributes final:[:]
app:7062024-11-25 12:50:51.176 PMdebuggetDeviceAttributes trait:Brightness
app:7062024-11-25 12:50:51.174 PMdebuggetDeviceAttributes trait:OnOff
app:7062024-11-25 12:50:51.172 PMdebuggetDeviceAttributes device:Guest Bedroom Lamp, deviceType:[name:Dimmer, type:LIGHT, specificCaps:[Switch Level], traits:[OnOff, Brightness], heAttributes:[switch, level]]
app:7062024-11-25 12:50:51.170 PMdebuggetDeviceType final:[name:Dimmer, type:LIGHT, specificCaps:[Switch Level], traits:[OnOff, Brightness], heAttributes:[switch, level]]
app:7062024-11-25 12:50:51.168 PMdebuggetDeviceType intermediate:[switch, level]
app:7062024-11-25 12:50:51.166 PMdebuggetDeviceType added:level
app:7062024-11-25 12:50:51.164 PMdebuggetDeviceType added:switch
app:7062024-11-25 12:50:51.161 PMdebuggetDeviceType device:Guest Bedroom Lamp, attributes:[switch, level, switch]
app:7062024-11-25 12:50:51.159 PMdebuggetDeviceAttributes final:[:]
app:7062024-11-25 12:50:51.157 PMdebuggetDeviceAttributes trait:Brightness
app:7062024-11-25 12:50:51.155 PMdebuggetDeviceAttributes trait:OnOff
app:7062024-11-25 12:50:51.152 PMdebuggetDeviceAttributes device:Family Room Ceiling Light, deviceType:[name:Dimmer, type:LIGHT, specificCaps:[Switch Level], traits:[OnOff, Brightness], heAttributes:[switch, level]]
app:7062024-11-25 12:50:51.149 PMdebuggetDeviceType final:[name:Dimmer, type:LIGHT, specificCaps:[Switch Level], traits:[OnOff, Brightness], heAttributes:[switch, level]]
app:7062024-11-25 12:50:51.147 PMdebuggetDeviceType intermediate:[switch, level]
app:7062024-11-25 12:50:51.145 PMdebuggetDeviceType added:level
app:7062024-11-25 12:50:51.143 PMdebuggetDeviceType added:switch
app:7062024-11-25 12:50:51.141 PMdebuggetDeviceType device:Family Room Ceiling Light, attributes:[switch, level, switch]
app:7062024-11-25 12:50:51.139 PMdebuggetDeviceAttributes final:[temperatureMinK:2000, temperatureMaxK:6500, colorModel:rgb]
app:7062024-11-25 12:50:51.137 PMdebuggetDeviceAttributes trait:ColorSpectrum
app:7062024-11-25 12:50:51.135 PMdebuggetDeviceAttributes trait:ColorTemperature
app:7062024-11-25 12:50:51.133 PMdebuggetDeviceAttributes trait:Brightness
app:7062024-11-25 12:50:51.131 PMdebuggetDeviceAttributes trait:OnOff
app:7062024-11-25 12:50:51.128 PMdebuggetDeviceAttributes device:Cassidy's Lamp, deviceType:[name:RGBW Light, type:LIGHT, specificCaps:[Color Mode], traits:[OnOff, Brightness, ColorTemperature, ColorSpectrum], heAttributes:[switch, level, colorTemperature, hue, saturation, colorMode]]
app:7062024-11-25 12:50:51.124 PMdebuggetDeviceType final:[name:RGBW Light, type:LIGHT, specificCaps:[Color Mode], traits:[OnOff, Brightness, ColorTemperature, ColorSpectrum], heAttributes:[switch, level, colorTemperature, hue, saturation, colorMode]]
app:7062024-11-25 12:50:51.121 PMdebuggetDeviceType intermediate:[hue, saturation, colorTemperature, level, switch, colorMode]
app:7062024-11-25 12:50:51.118 PMdebuggetDeviceType added:colorMode
app:7062024-11-25 12:50:51.115 PMdebuggetDeviceType added:switch
app:7062024-11-25 12:50:51.112 PMdebuggetDeviceType added:level
app:7062024-11-25 12:50:51.109 PMdebuggetDeviceType added:colorTemperature
app:7062024-11-25 12:50:51.106 PMdebuggetDeviceType added:saturation
app:7062024-11-25 12:50:51.104 PMdebuggetDeviceType added:hue
app:7062024-11-25 12:50:51.101 PMdebuggetDeviceType device:Cassidy's Lamp, attributes:[colorName, colorName, hue, color, saturation, colorTemperature, level, switch, switch, colorMode, RGB]
app:7062024-11-25 12:50:51.098 PMdebuggetDeviceAttributes final:[:]
app:7062024-11-25 12:50:51.096 PMdebuggetDeviceAttributes trait:Brightness
I can give more of the logs if needed
that pasted terribly sorry about that but it stops right after that error.
Although after all that I removed the fan and it worked... I guess I need to figure out what changed in this inovelli fan driver code.
can you post a screen shot of the fan device current states?, i think in know whats going on with it.
Well that would be awesome because I could never get this to work in google without over automating it. (google only thinks this is a light)
Um, yeah, that for sure isn't a fan as far as hubitat is concerned, this is what a fan looks like:
Interesting. Thats good news although this used to work just fine to sync with google. Then I would use google automation to trick it into turning the fan on/off. I will have to do some more digging thanks for your help.
Maybe I need to mess with the child device some more. I see that here
I got the same thing going on (except I haven't yet purchased a C8-Pro), am still on a C-5. I have a total of 7 Z-wave based devices in question: (A) 2 old Inovelli LZW36s (where each ceiling fan is a child device); (B) a GE Enbrighten Z-wave Fan Control (55258-1); (C) 2 GE Smart Fan Controls (14287); (D) a Honeywell Fan Control (39358) that I have installed to control an exhaust vent; and, (E) another GE Enbrighten Z-wave Fan Control (55258-1) that I have installed to control an exhaust vent. All except the Inovellis, (B) - (E) are set to the same Hubitat driver "GE Smart Fan Control", but only (B) shows up in Google Home without issue. (A) and (C) have the similar effect as previously mentioned except I get a HTTP 500 instead. With (D) and (E) simply being ignored (as far as I can tell). Previously, I had ALL of them exposed using the user-provided App (Google Home Community) and they have worked without issue.
With the recent addition of more device types in the GH integration we needed to tighten up how the devices were identified and federated into Google Home, so now some devices that don't specifically follow our capabilities and attributes can be dropped or possibly miss identified where they weren't before.
If devices are being dropped (as seen in the live logs) after being added, please enable the debug logging in the app, then add the device again, the information provided can help me identify what the integration doesn't like, and perhaps allow us to provide a way of including the device in the future.
My google comunity app stopped working (i only used it for fan controls in the home app) the built in app had me change speeds with numbers while i could use low, mid or high via the community app.. Recently i included the fan directly, and i have that exact error you are getting i have 6 fans though 5 are contolled by bond the one is an inovelli... Ill remove tbe inovelly to see if its the culprit.. If so.. I wonder why.. It was never an issue before
