How do I control my fan from google home. I have a Inovelli fan and light switch. When it comes into google home it comes in as a light. I am using the Hubitat device driver.
You can usually just treat a fan like a dimmable light. Just issue commands like "OK Google, set Family Room Fan to 50%"
If you run into the issue where setting the brightness of your room's lights also adjusts the fan speed, put the fan into a separate room in the Google home app (I.E. Living Room Other). The fan will still work with setting a percentage and will not adjust with the room's lights.
