I'm getting the following repeating error log with the Google Home integration......I know nothing on code so any help is appreciated......
Hmmm, did you recently change your Google password? Are you using the same Google account that you signed up your HE hub with?
Those are the only two things I can think of off the top of my head.
Yes, nothing changed......I did notice my google speaker wifi light blinking (as to losing connection) but once I reset it, I was still getting that error.
Something magical happened (as in I didn't change anything) and it works now (thanks to @bobbyD with support)
I am having the same problem, it started after I updated hub to version 2.1.9.115, this is in log syncResponse Error: { "error": { "code": 500, "message": "Internal error encountered.", "status": "INTERNAL" } } , giving up for now
And when i try command from google home it tries and it says "it looks that Hubitat is unavailable right now"
What magical thing did he do to fix it?
You will need to ask him, hopefully he can remember 10 months ago
Hahah, yeah. Missed the age of the post, browsing through unread stuff.
Thats a few releases ago too.
I solved it by unlinking and relinking google account, thanks
