Google-Compatible Devices Can't get added to Google Home App in Hubitat
I have 3 Sengled Element Color Plus lightbulbs that i just set up with my elevation hubitat c-7. I installed the Google Home app, (which by the way, in the tutorial, doesn't tell you that you have to add the devices to the Google Home app first before authorization them with Google, lol) however when I add the 3 lightbulbs to that app, only one ('Clip Light') ends up working. In the logs, i see this warning:
app:5 2025-01-12 10:20:35.418 PM warn
The following devices are not supported by Google Home and will be removed from your device list:[Desk Light, Dresser Light]
They're all the same lightbulb (they came in a 4 pack), so why would this be happening?
This is probably due to some of the lights not listing attributes that Google requires. Look at the Current States for the one that is working. Note what states are listed. This is one of my Sengled bulbs:
Check the device page for the ones that aren't working. Are they missing any of those attributes? If so, use the command buttons on the device page to set the missing attribute(s). For example, if the bulb doesn't have a hue attribute, set a hue. If it doesn't list a color temperature, set a color temperature, etc.
Once you have all the attributes showing up on the non-working bulbs, try to add them to Google in the Google Home Hubitat app again.
I just revisited this and was able to add them without issue. Thank you for the tips
