Hi,
I have different modes that trigger my alarms to go on or off. When I trigger a mode through a routine in google assistant, it gives me the following error after the routine is executed. The routine is to change the mode to night mode, which executes successfully.
Please see attached. Night mode switches the Hubitat Safety Montor to Night Mode and arms the system. The Goole Assistant Hubitat app makes the different scenes / modes visible on Google Assistant. The google assistant scene is triggered through GA on google mini or any other GA device like a phone. It seems now that the scene is executed correctly and it switches to Night Mode however it always still gives the error. This error is through any GA device
Well, #1, I am not having any trouble controlling my Hubitat devices with Google Home right now. And #2, I don't think they have ever worked correctly from Google Home. What I would do instead is use a virtual switch. You can set up the switch to activate night mode by Rule Machine. You can that set that routine to turn off the virtual switch. You can then have the virtual switch turn itself off after so many seconds. I know it's a longer workaround but there has been a report about that as a known issue with the google integration.
Just to clarify though...the problem is on the feedback to Google home...it will set the mode the way that you have requested.
Everything seems to work Lights etc. Its only when I set the scene to night mode that this error message appears. Again it does change it to night mode despite the error.
This has been a known issue for quite some time but you're welcome to raise the issue via support@hubitat.com Like I said, using the virtual switch is a way to eliminate this problem.
And FYI.....it has nothing to do with the Google services being down. Search for Google and Mode here on the forum and you'll see a half dozen posts at least about the same error going back months. And, as you note, the action does take place on Hubitat, just the error is also posted. So, the action is clearly happening. Otherwise the mode wouldn't change.
This worked great. I setup the virtual switch to turn itself off after the mode changes. A timer may be a better idea so I don't get stuck in a loop but tests have gone well.
