I've spent a good deal of time looking in this community as well as on the web and I'm getting more confused by the click.
I need a smart receptacle with USB connections as well. It needs to:
- Not be a plug-in, installed in box only
- Have 2 standard, grounded 120V outlets with 15A capacity
- Single control of both outlets is preferred but separate control is acceptable
- Have 2 USB Type A connectors with at least 1A at 5V on each
- Have USB that is powered independently, not switched with 120V outlets
- Be compatible with HE via either Z-wave or Zigbee
It is also highly preferred that an HE user has one of these so it is known to work as intended.
Your suggestions will be very much appreciated.
P.S. I'm aware of workarounds with plug-ins and will go that route if this clean solution isn't available.
