I have an app to switch my GoControl Thermostat from Heat mode (which runs the Heat Pump), to Emergency Heat (gas-fired water baseboard heat) when the Outside Air Temperature drops below 30°F. Right now it's 10°F outside here in New York state and the heat pump is still running and no heat at the baseboard. The thermostat would not respond to manual commands from the website either. I had to go to the thermostat and physically cycle it to emergency heat. Does anyone know why this may be?
Commands
Auto
auto
Configure
configure
Cool
cool
Emergency Heat
emergencyHeat
Fan Auto
fanAuto
Fan Circulate
fanCirculate
Fan On
fanOn
Heat
heat
Initialize
initialize
Off
off
Refresh
refresh
Set Cooling Setpoint
setCoolingSetpoint
Set Heating Setpoint
setHeatingSetpoint
Set Thermostat Fan Mode
setThermostatFanMode
Set Thermostat Mode
setThermostatMode
Current States
- battery : 100
- coolingSetpoint : 78
- heatingSetpoint : 72
- supportedThermostatFanModes : ["auto","on"]
- supportedThermostatModes : ["off","heat","cool","auto","emergency heat"]
- temperature : 70
- thermostatFanMode : auto
- thermostatMode : emergency heat
- thermostatOperatingState : heating
- thermostatSetpoint : 72
State Variables
Preferences
Advanced
Device Details
| Create Time | 2022-12-19 10:31:44am EST |
| Last Update Time | 2022-12-19 10:32:59am EST |
| Last Activity At | 2022-12-23 7:37:08pm EST |
| Controller Type | ZWV |
| Data | * deviceId: 21559 |
- deviceType: 21570
- inClusters: 0x5E,0x59,0x5A,0x40,0x42,0x43,0x44,0x45,0x80,0x70,0x31,0x8F,0x86,0x72,0x85,0x2C,0x2B,0x73,0x81,0x7A
- lastRunningMode: heat
- manufacturer: 335
- zwNodeInfo: 53 DC 00 04 08 06 5E 59 5A 40 42 43 44 45 80 70 31 8F 86 72 85 5C 2C 2B 73 81 7A 68 23|
|In Use By|* Fri-Sat PM Master Bedroom (Rule-5.1) - House Empty > 24 Hours (Rule-5.1)
- House Empty > 4 Hours (Rule-5.1)
- MBR Thermostat Switch from Cool to Heat (Rule-5.1)
- MBR Thermostat Switch from Emerg Heat to Heat (Rule-5.1)
- MBR Thermostat Switch from Emerg Heat to Heat - Winter Months (Rule-5.1)
- MBR Thermostat Switch from Heat to Cool (Rule-5.1)
- MBR Thermostat Switch from Heat to Emerg Heat (Rule-5.1)
- MBR Thermostat Switch from Heat to Emergency Heat - Winter Months (Rule-5.1)
- Mon-Fri AM Master Bedroom (Rule-5.1)
- Our Home Dashboard (Dashboard)
- Sat-Sun AM Master Bedroom (Rule-5.1)
- Someone Returns Home - Day (Rule-5.1)
- Someone Returns Home - Night (Rule-5.1)
- Someone Returns Home - Night Bitter Cold (Rule-5.1)
- Sun-Thurs PM Master Bedroom (Rule-5.1)|
