Not sure if this will work (or even compile) as I'm not where I can test at the moment (also don't have a device to test with even if I were able to test the compile), but a quick port of the ST driver:
Ported Driver
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Z-Wave Metering Switch - Ported", namespace: "smartthings", author: "SmartThings", ocfDeviceType: "oic.d.switch", runLocally: true, minHubCoreVersion: '000.017.0012', executeCommandsLocally: false, genericHandler: "Z-Wave") {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Power Meter"
capability "Refresh"
capability "Configuration"
capability "Sensor"
capability "Light"
capability "Health Check"
command "reset"
fingerprint inClusters: "0x25,0x32", deviceJoinName: "Switch"
fingerprint mfr: "0086", prod: "0003", model: "0012", deviceJoinName: "Aeotec Switch" //Aeotec Micro Smart Switch
fingerprint mfr: "021F", prod: "0003", model: "0087", deviceJoinName: "Dome Outlet", ocfDeviceType: "oic.d.smartplug" //Dome On/Off Plug-in Switch
fingerprint mfr: "0086", prod: "0103", model: "0060", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug" //US //Aeotec Smart Switch 6
fingerprint mfr: "0086", prod: "0003", model: "0060", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug" //EU //Aeotec Smart Switch 6
fingerprint mfr: "0086", prod: "0203", model: "0060", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug" //AU //Aeotec Smart Switch 6
fingerprint mfr: "0086", prod: "0103", model: "0074", deviceJoinName: "Aeotec Switch" //Aeotec Nano Switch
fingerprint mfr: "0086", prod: "0003", model: "0074", deviceJoinName: "Aeotec Switch" //Aeotec Nano Switch
fingerprint mfr: "0086", prod: "0203", model: "0074", deviceJoinName: "Aeotec Switch" //AU //Aeotec Nano Switch
fingerprint mfr: "014F", prod: "574F", model: "3535", deviceJoinName: "GoControl Outlet", ocfDeviceType: "oic.d.smartplug" //GoControl Wall-Mounted Outlet
fingerprint mfr: "014F", prod: "5053", model: "3531", deviceJoinName: "GoControl Outlet", ocfDeviceType: "oic.d.smartplug" //GoControl Plug-in Switch
fingerprint mfr: "0063", prod: "4F44", model: "3031", deviceJoinName: "GE Switch" //GE Direct-Wire Outdoor Switch
fingerprint mfr: "0258", prod: "0003", model: "0087", deviceJoinName: "NEO Coolcam Outlet", ocfDeviceType: "oic.d.smartplug" //NEO Coolcam Power plug
fingerprint mfr: "010F", prod: "0602", model: "1001", deviceJoinName: "Fibaro Outlet", ocfDeviceType: "oic.d.smartplug" // EU //Fibaro Wall Plug ZW5
fingerprint mfr: "010F", prod: "1801", model: "1000", deviceJoinName: "Fibaro Outlet", ocfDeviceType: "oic.d.smartplug"// UK //Fibaro Wall Plug ZW5
fingerprint mfr: "0086", prod: "0003", model: "004E", deviceJoinName: "Aeotec Switch" //EU //Aeotec Heavy Duty Smart Switch
fingerprint mfr: "0086", prod: "0103", model: "004E", deviceJoinName: "Aeotec Switch" //US //Aeotec Heavy Duty Smart Switch
//zw:L type:1001 mfr:0258 prod:0003 model:1087 ver:3.94 zwv:4.05 lib:03 cc:5E,72,86,85,59,5A,73,70,25,27,71,32,20 role:05 ff:8700 ui:8700
fingerprint mfr: "0258", prod: "0003", model: "1087", deviceJoinName: "NEO Coolcam Outlet", ocfDeviceType: "oic.d.smartplug" //EU //NEO Coolcam Power Plug
fingerprint mfr: "027A", prod: "0101", model: "000D", deviceJoinName: "Zooz Switch" //Zooz Power Switch
fingerprint mfr: "0159", prod: "0002", model: "0054", deviceJoinName: "Qubino Outlet", ocfDeviceType: "oic.d.smartplug" //Qubino Smart Plug
fingerprint mfr: "0371", prod: "0003", model: "00AF", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug" //EU //Aeotec Smart Switch 7
fingerprint mfr: "0371", prod: "0103", model: "0017", deviceJoinName: "Aeotec Outlet", ocfDeviceType: "oic.d.smartplug" //US //Aeotec Smart Switch 7
fingerprint mfr: "0060", prod: "0004", model: "000B", deviceJoinName: "Everspring Outlet", ocfDeviceType: "oic.d.smartplug" //US //Everspring Smart Plug
fingerprint mfr: "031E", prod: "0002", model: "0001", deviceJoinName: "Inovelli Switch" //US //Inovelli Switch Red Series
fingerprint mfr: "0154", prod: "0003", model: "000A", deviceJoinName: "POPP Outlet", ocfDeviceType: "oic.d.smartplug" //EU //POPP Smart Outdoor Plug
fingerprint mfr: "010F", prod: "1F01", model: "1000", deviceJoinName: "Fibaro Outlet", ocfDeviceType: "oic.d.smartplug" //EU //Fibaro walli Outlet //Fibaro Outlet
def installed() {
log.debug "installed()"
// Device-Watch simply pings if no device events received for 32min(checkInterval)
initialize()
if (zwaveInfo?.mfr?.equals("0063") || zwaveInfo?.mfr?.equals("014F")) { // These old GE devices have to be polled. GoControl Plug refresh status every 15 min.
runEvery15Minutes("poll", [forceForLocallyExecuting: true])
def updated() {
initialize()
unschedule("poll", [forceForLocallyExecuting: true])
try {
if (!state.MSR) {
response(zwave.manufacturerSpecificV2.manufacturerSpecificGet().format())
} catch (e) {
log.debug e
def initialize() {
sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
def getCommandClassVersions() {
0x20: 1, // Basic
0x32: 3, // Meter
0x56: 1, // Crc16Encap
0x70: 1, // Configuration
0x72: 2, // ManufacturerSpecific
// parse events into attributes
log.debug "parse() - description: "+description
def result = null
if (description != "updated") {
def cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
result = zwaveEvent(cmd)
log.debug("'$description' parsed to $result")
} else {
log.debug("Couldn't zwave.parse '$description'")
result
def handleMeterReport(cmd){
if (cmd.meterType == 1) {
if (cmd.scale == 0) {
createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kWh")
} else if (cmd.scale == 1) {
createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kVAh")
} else if (cmd.scale == 2) {
createEvent(name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W")
def zwaveEvent(hubitat.zwave.commands.meterv3.MeterReport cmd) {
log.debug "v3 Meter report: "+cmd
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd)
log.debug "Basic report: "+cmd
def value = (cmd.value ? "on" : "off")
def evt = createEvent(name: "switch", value: value, type: "physical", descriptionText: "$device.displayName was turned $value")
if (evt.isStateChange) {
[evt, response(["delay 3000", meterGet(scale: 2).format()])]
} else {
evt
def zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
log.debug "Switch binary report: "+cmd
createEvent(name: "switch", value: value, type: "digital", descriptionText: "$device.displayName was turned $value")
def zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def result = []
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug "msr: $msr"
updateDataValue("MSR", msr)
result << createEvent(descriptionText: "$device.displayName MSR: $msr", isStateChange: false)
def zwaveEvent(hubitat.zwave.Command cmd) {
log.debug "${device.displayName}: Unhandled: $cmd"
def on() {
encapSequence([
zwave.basicV1.basicSet(value: 0xFF),
zwave.switchBinaryV1.switchBinaryGet(),
meterGet(scale: 2)
], 3000)
def off() {
encapSequence([
zwave.basicV1.basicSet(value: 0x00),
meterGet(scale: 2)
], 3000)
* PING is used by Device-Watch in attempt to reach the Device
def ping() {
log.debug "ping()"
refresh()
def poll() {
sendHubCommand(refresh())
def refresh() {
log.debug "refresh()"
encapSequence([
meterGet(scale: 0),
meterGet(scale: 2)
def configure() {
log.debug "configure()"
def result = []
log.debug "Configure zwaveInfo: "+zwaveInfo
if (zwaveInfo.mfr == "0086") { // Aeon Labs meter
result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 80, size: 1, scaledConfigurationValue: 2))) // basic report cc
result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 101, size: 4, scaledConfigurationValue: 12))) // report power in watts
result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 111, size: 4, scaledConfigurationValue: 300))) // every 5 min
} else if (zwaveInfo.mfr == "010F" && zwaveInfo.prod == "1801" && zwaveInfo.model == "1000") { // Fibaro Wall Plug UK
result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 11, size: 1, scaledConfigurationValue: 2))) // 2% power change results in report
result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 13, size: 2, scaledConfigurationValue: 5*60))) // report every 5 minutes
} else if (zwaveInfo.mfr == "014F" && zwaveInfo.prod == "5053" && zwaveInfo.model == "3531") {
result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 13, size: 2, scaledConfigurationValue: 15))) //report kWH every 15 min
} else if (zwaveInfo.mfr == "0154" && zwaveInfo.prod == "0003" && zwaveInfo.model == "000A") {
result << response(encap(zwave.configurationV1.configurationSet(parameterNumber: 25, size: 1, scaledConfigurationValue: 1))) //report every 1W change
result << response(encap(meterGet(scale: 0)))
result << response(encap(meterGet(scale: 2)))
result
def reset() {
encapSequence([
meterReset(),
meterGet(scale: 0)
def meterGet(map)
return zwave.meterV2.meterGet(map)
def meterReset()
return zwave.meterV2.meterReset()
* Security encapsulation support:
def zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand(commandClassVersions)
if (encapsulatedCommand) {
log.debug "Parsed SecurityMessageEncapsulation into: ${encapsulatedCommand}"
zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract Secure command from $cmd"
def zwaveEvent(hubitat.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def version = commandClassVersions[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
log.debug "Parsed Crc16Encap into: ${encapsulatedCommand}"
} else {
log.warn "Unable to extract CRC16 command from $cmd"
private secEncap(hubitat.zwave.Command cmd) {
log.debug "encapsulating command using Secure Encapsulation, command: $cmd"
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private crcEncap(hubitat.zwave.Command cmd) {
log.debug "encapsulating command using CRC16 Encapsulation, command: $cmd"
zwave.crc16EncapV1.crc16Encap().encapsulate(cmd).format()
private encap(hubitat.zwave.Command cmd) {
if (zwaveInfo?.zw?.contains("s")) {
secEncap(cmd)
} else if (zwaveInfo?.cc?.contains("56")){
crcEncap(cmd)
} else {
log.debug "no encapsulation supported for command: $cmd"
cmd.format()
private encapSequence(cmds, Integer delay=250) {
delayBetween(cmds.collect{ encap(it) }, delay)
