I didn't test it or change the header/revision text, but here you go. It saves without errors, but that doesn't mean it will work without errors.
Hard to test w/o the device.
* GoControl Motion Sensor v1.3.6
* (Model: WAPIRZ-1)
* Author:
* Kevin LaFramboise (krlaframboise)
* URL to documentation:
* https://community.smartthings.com/t/release-gocontrol-door-window-sensor-motion-sensor-and-siren-dth/50728?u=krlaframboise
* Changelog:
* 1.3.6 (09/10/2017)
* - Removed old style fingerprint to eliminate conflicts with other generic sensors.
* 1.3.5 (09/01/2017)
* - Added workaround for SmartThings breaking the convertTemperatureIfNeeded function for precision 0.
* - Added +52°F offset when the temperature is <= -21°F to correct a firmware bug.
* 1.3.2 (04/23/2017)
* - SmartThings broke parse method response handling so switched to sendhubaction.
* 1.3.1 (04/20/2017)
* - Added fingerprint.
* - Added workaround for ST Health Check bug.
* 1.3 (03/12/2017)
* - Added Health Check.
* 1.2.1 (07/31/2016)
* - Fix iOS UI bug with tamper tile.
* - Removed secondary tile.
* 1.1 (06/17/2016)
* - Fixed tamper detection
* 1.0 (06/17/2016)
* - Initial Release
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name:"GoControl Motion Sensor", namespace:"krlaframboise", author: "Kevin LaFramboise") {
capability "Sensor"
capability "Battery"
capability "Motion Sensor"
capability "Temperature Measurement"
capability "Tamper Alert"
capability "Refresh"
capability "Configuration"
capability "Health Check"
attribute "lastCheckin", "string"
fingerprint mfr:"014F", prod:"2002", model:"0203"
// fingerprint deviceId:"0x2001", inClusters:"0x71, 0x85, 0x80, 0x72, 0x30, 0x86, 0x31, 0x70, 0x84"
preferences {
input "temperatureOffset", "number",
title: "Temperature Offset:\n(Allows you to adjust the temperature being reported if it's always high or low by a specific amount. Example: Enter -3 to make it report 3° lower or enter 3 to make it report 3° higher.)",
range: "-100..100",
defaultValue: tempOffsetSetting,
displayDuringSetup: true,
required: false
input "temperatureThreshold", "number",
title: "Temperature Change Threshold:\n(You can use this setting to prevent the device from bouncing back and forth between the same two temperatures. Example: If the device is repeatedly reporting 68° and 69°, you can change this setting to 2 and it won't report a new temperature unless 68° changes to 66° or 70°.)",
range: "1..100",
defaultValue: tempThresholdSetting,
required: false
input "retriggerWaitTime", "number",
title: "Re-Trigger Wait Time (Minutes)\n(When the device detects motion, it waits for at least 1 minute of inactivity before sending the inactive event. The default re-trigger wait time is 3 minutes.)",
range: "1..255",
defaultValue: retriggerWaitTimeSetting,
required: false
input "checkinInterval", "enum",
title: "Checkin Interval:",
defaultValue: checkinIntervalSetting,
required: false,
options: checkinIntervalOptions.collect { it.name }
input "reportBatteryEvery", "enum",
title: "Battery Reporting Interval:",
defaultValue: batteryReportingIntervalSetting,
required: false,
input "debugOutput", "bool",
title: "Enable debug logging?",
defaultValue: false,
required: false
def updated() {
if (!isDuplicateCommand(state.lastUpdated, 3000)) {
state.lastUpdated = new Date().time
logTrace "updated()"
refresh()
def configure() {
logTrace "configure()"
def cmds = []
if (!device.currentValue("motion")) {
sendEvent(name: "motion", value: "active", isStateChange: true, displayed: false)
if (!state.isConfigured) {
logTrace "Waiting 1 second because this is the first time being configured"
// Give inclusion time to finish.
cmds << "delay 1000"
initializeCheckin()
cmds += [
wakeUpIntervalSetCmd(checkinIntervalSettingMinutes),
retriggerWaitTimeSetCmd(),
batteryGetCmd(),
temperatureGetCmd()
return delayBetween(cmds, 250)
private initializeCheckin() {
// Set the Health Check interval so that it can be skipped once plus 2 minutes.
def checkInterval = ((checkinIntervalSettingMinutes * 2 * 60) + (2 * 60))
sendEvent(name: "checkInterval", value: checkInterval, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
def refresh() {
clearTamperDetected()
logDebug "The re-trigger wait time will be sent to the device the next time it wakes up. If you want this change to happen immediately, open the back cover of the device until the red light turns solid and then close it."
state.pendingConfig = true
private clearTamperDetected() {
if (device.currentValue("tamper") != "clear") {
logDebug "Resetting Tamper"
sendEvent(getTamperEventMap("clear"))
private retriggerWaitTimeSetCmd() {
logTrace "Setting re-trigger wait time to ${retriggerWaitTimeSetting} minutes"
return zwave.configurationV1.configurationSet(scaledConfigurationValue: retriggerWaitTimeSetting, parameterNumber: 1, size: 1).format()
private wakeUpIntervalSetCmd(minutesVal) {
state.checkinIntervalMinutes = minutesVal
logTrace "wakeUpIntervalSetCmd(${minutesVal})"
return zwave.wakeUpV2.wakeUpIntervalSet(seconds:(minutesVal * 60), nodeid:zwaveHubNodeId).format()
private wakeUpNoMoreInfoCmd() {
return zwave.wakeUpV2.wakeUpNoMoreInformation().format()
private temperatureGetCmd() {
return zwave.sensorMultilevelV2.sensorMultilevelGet().format()
private batteryGetCmd() {
return zwave.batteryV1.batteryGet().format()
// log.trace "$description"
def result = []
sendEvent(name: "lastCheckin", value: convertToLocalTimeString(new Date()), displayed: false, isStateChange: true)
def cmd = zwave.parse(description, [0x71: 2, 0x80: 1, 0x30: 1, 0x31: 2, 0x70: 1, 0x84: 1])
if (cmd) {
result += zwaveEvent(cmd)
else {
logDebug "Unknown Description: $desc"
return result
def zwaveEvent(hubitat.zwave.commands.wakeupv1.WakeUpNotification cmd)
logTrace "WakeUpNotification"
def result = []
if (state.pendingConfig) {
state.pendingConfig = false
result += configure()
else if (canReportBattery()) {
result << batteryGetCmd()
if (result) {
result << "delay 2000"
result << wakeUpNoMoreInfoCmd()
return sendResponse(result)
private sendResponse(cmds) {
def actions = []
cmds?.each { cmd ->
actions << new hubitat.device.HubAction(cmd)
sendHubCommand(actions)
return []
private canReportBattery() {
def reportEveryMS = (batteryReportingIntervalSettingMinutes * 60 * 1000)
return (!state.lastBatteryReport || ((new Date().time) - state.lastBatteryReport > reportEveryMS))
def zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
def motionVal = cmd.value ? "active" : "inactive"
def desc = "Motion is $motionVal"
logDebug "$desc"
def result = []
result << createEvent(name: "motion",
value: motionVal,
displayed: true,
descriptionText: "$desc")
return result
def zwaveEvent(hubitat.zwave.commands.batteryv1.BatteryReport cmd) {
logTrace "BatteryReport: $cmd"
def val = (cmd.batteryLevel == 0xFF ? 1 : cmd.batteryLevel)
if (val > 100) {
val = 100
state.lastBatteryReport = new Date().time
logDebug "Battery ${val}%"
def isNew = (device.currentValue("battery") != val)
def result = []
result << createEvent(name: "battery", value: val, unit: "%", display: isNew, isStateChange: isNew)
return result
def zwaveEvent(hubitat.zwave.commands.alarmv2.AlarmReport cmd) {
def result = []
if (cmd.alarmType == 7 && cmd.alarmLevel == 0xFF && cmd.zwaveAlarmEvent == 3) {
logDebug "Tampering Detected"
result << createEvent(getTamperEventMap("detected"))
return result
def getTamperEventMap(val) {
value: val,
displayed: (val == "detected"),
descriptionText: "Tamper is $val"
def zwaveEvent(hubitat.zwave.Command cmd) {
logDebug "Unknown Command: $cmd"
return []
def zwaveEvent(hubitat.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd){
// logTrace "SensorMultilevelReport: $cmd"
def result = []
if (cmd.sensorType == 1) {
def cmdScale = cmd.scale == 1 ? "F" : "C"
// Workaround for firmware bug that adds a -52°F offset when temperature drops below 32°F
def sensorVal = (cmd.scaledSensorValue <= -21) ? cmd.scaledSensorValue + 52 : cmd.scaledSensorValue
def temp = "${convertTemperatureIfNeeded(sensorVal, cmdScale, cmd.precision)}"
def newTemp = safeToInt(temp.endsWith(".") ? temp.replace(".", "") : temp)
if (tempOffsetSetting != 0) {
newTemp = (newTemp + tempOffsetSetting)
logDebug "Adjusted temperature by ${tempOffsetSetting}°"
def highTemp = (getCurrentTemp() + tempThresholdSetting)
def lowTemp = (getCurrentTemp() - tempThresholdSetting)
if (newTemp >= highTemp || newTemp <= lowTemp) {
value: newTemp,
unit: getTemperatureScale(),
displayed: true)
else {
logDebug "Ignoring new temperature of $newTemp° because the change is within the ${tempThresholdSetting}° threshold."
return result
private getRetriggerWaitTimeSetting() {
return safeToInt(settings?.retriggerWaitTime, 3)
private getCurrentTemp() {
return safeToInt(device.currentValue("temperature"), 0)
private getTempThresholdSetting() {
return safeToInt(settings?.temperatureThreshold, 1)
private getTempOffsetSetting() {
return safeToInt(settings?.temperatureOffset, 0)
// Settings
private getCheckinIntervalSettingMinutes() {
return convertOptionSettingToInt(checkinIntervalOptions, checkinIntervalSetting) ?: 360
private getCheckinIntervalSetting() {
return settings?.checkinInterval ?: findDefaultOptionName(checkinIntervalOptions)
private getBatteryReportingIntervalSettingMinutes() {
return convertOptionSettingToInt(checkinIntervalOptions, batteryReportingIntervalSetting) ?: 720
private getBatteryReportingIntervalSetting() {
return settings?.reportBatteryEvery ?: findDefaultOptionName(checkinIntervalOptions)
private getCheckinIntervalOptions() {
[name: "10 Minutes", value: 10],
[name: "15 Minutes", value: 15],
[name: "30 Minutes", value: 30],
[name: "1 Hour", value: 60],
[name: "2 Hours", value: 120],
[name: "3 Hours", value: 180],
[name: formatDefaultOptionName("6 Hours"), value: 360],
[name: "9 Hours", value: 540],
[name: "12 Hours", value: 720],
[name: "18 Hours", value: 1080],
[name: "24 Hours", value: 1440]
private convertOptionSettingToInt(options, settingVal) {
return safeToInt(options?.find { "${settingVal}" == it.name }?.value, 0)
private formatDefaultOptionName(val) {
return "${val}${defaultOptionSuffix}"
private findDefaultOptionName(options) {
def option = options?.find { it.name?.contains("${defaultOptionSuffix}") }
return option?.name ?: ""
private getDefaultOptionSuffix() {
return " (Default)"
private safeToInt(val, defaultVal=-1) {
return "${val}"?.isInteger() ? "${val}".toInteger() : defaultVal
private convertToLocalTimeString(dt) {
def timeZoneId = location?.timeZone?.ID
if (timeZoneId) {
return dt.format("MM/dd/yyyy hh:mm:ss a", TimeZone.getTimeZone(timeZoneId))
else {
return "$dt"
private isDuplicateCommand(lastExecuted, allowedMil) {
!lastExecuted ? false : (lastExecuted + allowedMil > new Date().time)
private logDebug(msg) {
if (settings?.debugOutput || settings?.debugOutput == null) {
log.debug "$msg"
private logTrace(msg) {
// log.trace "$msg"
