Although this will be a device specific question, I am sure the same method will apply to other devices.
I am using the user driver for my GoControl GC-TBZ48 thermostat. Every thing is working great.
The driver comes with the ability to show replacement status which I have added to a dashboard so it's in my face when it comes time to change the filter.
Under the devices section (hubitat admin) for the thermostat there is a switch to resetFilter time after replacing the filter.
How can I use that reset filter function on a dashboard so that I don't have to go into the device under hubitat admin page settings to reset it?
Thanks in advance
Carey
Possibly create a virtual switch to expose to your dash board that set's the attribute?
Thanks for the response.
I have already tried that, but unfortunately that attribute is not one that can be selected.
I can view the code in the device admin, but I don't know how to copy that into a dashboard tile.
Ok, under the devices section for the thermostat, there is a button for filterReset.
This action does not appear to be available in any template so I can add it to a dashboard.
When I do an inspect via the browser, ehere is the code for the filterReset button under the devices admin:
<fieldset class="form-horizontal">
<input type="hidden" name="id" value="354">
<input type="hidden" name="method" value="filterReset">
</fieldset>
</form>
<script>
$('#tileContainter-filterReset-7').on('click',function(e) {
$('#form-filterReset-7').submit()
$('#form-filterReset-7').on('submit', function (e) {
e.preventDefault();
if(this.checkValidity()) {
//console.log("filterReset submit blocked");
$.ajax({
url: "/device/runmethod",
type: "POST",
context: this,
data: $(this).serialize(),
success: function (data) {
console.log("command sent");
error: function (data) {
} else {
alert('Please complete the required fields.')
</script>
Is there anyway I can get this mapped to a virtual button or switch device so I can add it to a dashboard. This is not available as an attribute that I can easily add to a dashboard.
Hope this helps clarify what I am looking for.
Hmmm Maybe @mike.maxwell or @bcopeland has some ideas on pulling that in easier
