I probably missed it elsewhere, but thought I'd ask about the GoControl Garage Door opener and why it's not pairing completely. I read some folks saying they had challenges initially and a difficult time figuring out why it didn't work, but I didn't see what the cause / conclusion was so figured I'd ask.
I can get it to pair (although it seems I had to reboot the hub). It uses the generic z-wave garage door opener. The problem is there are no logs, not current state, and the open close don't do anything. It's listed as a device, but that's it. Am I missing a step here?
Got it. I didn't have the SecurePairing in the data section so I removed the device and repaired. Not sure if there was something I was suppose to do more than that, but now it's there.
Unfortunately I had it working on my couch but now that it's at the garage door it's giving me this in the log:
OK, I think I got it working. Just for others, pretty sure my hub was too far away. I moved it and it could connect. The opener also requires the tilt sensor to be installed. I thought I'd mention it as I imagine it limits some of the functionality for some.
UL is Underwriters Laboratory, a safety testing lab. The rest of the UL requirements are the beeping and flashing before the door will close. There is a somewhat regular occurrence (after 2 years or so) of the flashing LED burning out causing the door to stop operating.
That's a bummer. Is it something I can replace? Or is it basically a throw-away item then? I'm on the fence as I could just get a momentary switch and use it with a sensor.
Wow, that's super helpful. Thanks for the share. I am fairly comfortable with an iron, but given the price I'm not sure it's worth it. I was considering getting FortrezZ Z-WavePlus MiMO2+, a couple of contact sensors and a siren (or speaker if that's too loud) to do the same thing, Not as secure and a little more all up, but then I could do both doors.
know of anyone who's gone that route with Hubitat?
I think I would do that if I had to do it from scratch. If/when my LED fails, I would probably try a repair first but would fall back to the dry contact route.
Thanks for this tip. Pairing it within 3 ft of the controller also did the trick for my unit. That and ensuring that the LED and BEEP functionality as well as the tilt sensor being paired all worked. Without the 3 safety features (tilt, beep, and LED blinking) the device might make sounds but will never actually send a signal to the pushbutton garage wires.
