I have a GoControl Garage door opener. Worked great with my C-4 hub. Then it stopped reporting status. I've replaced the battery in the tilt sensor twice with 2 brand new batteries. I've excluded the device and re-added it several times.
When taking the battery out and putting it back in the Go Control does beep so I'm pretty confident the main unit is still seeing the sensor.
I've included a screen shot of the device and logs from when I re-added it to my Hubitat. Haven't had a chance to troubleshoot it since August. Thanks in advance for the help!
For the C3-C5 it won't ask. I would say this one step was 90% of my problems with my first GDO.
I have two.. one's a GoControl and the other is Linear. Same manufacturer, just different logos
Migrating my Linear to Hubitat was a pain. I got these 'missing' S0 Security and of course nothing worked. Exclude/Include a bunch of times. Eventually I gave up and migrated other devices. At the end of the day, having migrated everything else, I tried the Linear GDO again and it worked first attempt. I've always 'blamed it' on having additional repeaters in the area. The initial repeater that was perfectly fine, close enough, etc. wasn't helpful enough, I am guessing. When 3 more got added during the remainder of the migration, one of them was good enough... is my conclusion.
I've since moved both of the GDOs from a C-5 to a C-7. First attempt. Both. I was expecting them to be a big problem... was anti-climatic. Again I conclude that the mesh for the C-7 had more options at the moment I did the Exclude/Include.
Also, be sure to reset the device before attempting to include it again. Exclusion in itself is not enough. I have a similar device and has been rock solid on C4, C5 and C7. Including it secure is the key.
Another Factoy reset and exclude/include and it's working. I'm showing securepairing complete: True. No idea why it didn't do it back in august. I must have done 5 or 5 factory resets that day. Worked on the first time. Maybe it was the update I just ran?
