Any chance to update the ZWave Generic Garage Door Driver that works with the GoControl Garage Door controller to support opening/closing for Sharptools.io? In Sharptools.io the "thing" only shows up as a contact resulting in you cannot control the garage door from Sharptools.io. Thoughts or suggestions?
what's it supposed to be?
it currently has the following, in addition to the contact capability
capability "Door Control"
capability "Garage Door Control"
Great question! When I attempt to connect the things between Sharptools.io and HE there is no option for my Garage Door controllers besides them being contacts. When using Sharptools.io with ST the Garage Doors are like switches but with open/close state.
Also I see Alexa skill not working with the garage doors either. Not sure if you can add the switch capability.
Thoughts on this?
Looks like shrptools.io is providing a fix.
It has been fixed!
