To start with I'm in FT Myers Florida , that is in SW Florida, ground zero for Hurricane Ian. My power was off for 4 days and the internet service a day later. Everything for the Hubitat came back and has actually worked flawlessly. I'm fairly certain the Go Control opener was was reporting accurately.
Now it does not work from the app and it is not reporting correctly . The only thing I have done is replaced the battery in the tilt sensor and unplugged the Garage controller but still doesn't work.
I'll remove it and reinstall tonight and hopefully that fixes it.
You can try the procedure to re-pair the sensor.
Unplug the controller for 10 seconds then plug it back in.
Then hold the reset button on the side for 10 seconds.
Then Raise and lower the door twice.
