Hi
I am trying to use global variables for color temperature and level.
I have tried to follow the instructions at
https://docs.hubitat.com/index.php?title=Rule-4.0#Global_Variables_may_be_used_for_Level.2FColor
I have created two global variables one called GlobalCT and one called GlobalLevel. Each one defined as a Number.
One has a Color Bulb connector the other Dimmer.
Then when I use "Color temperature per mode" only the GlobalCT is available as a device.
How do I set GlobalLevel with "Color temperature per mode" ?
Thanks,
Martin
