Global Variables not updating in triggered conditional rules
@bravenel
I believe I've discovered a bug in RM when a GV is used as a condition in a triggered/conditional rule. The issue is that the condition is not properly evaluating unless I go into the rule open the condition and then select done.
Example:
Trigger - Motion Active
Condition - Variable XX is true
Action - Turn on switch xx
Basically, the variable state doesn't appear to be updating properly so even if the variable state is true, RM is seeing it as false. Only appears to effect triggered/conditional rules. GV's used in a regular rule seem to update fine.
Yes, I think I know what the problem is. Will do a fix for that. Thanks...
