Global Cache
I installed the required "normal stuff library" but still can't get IP2IR.
Install Bundle
  • Switch will turn off when finished
Send IP2IR requires Normal Stuff Library be installed BEFORE Send IP2IR can be installed.
Is there another way to link the Global Cache ITach to Hubitat? If possible an actual step by step example would be great for all of us that are new to the HUB.
