Good morning community.
I am really new with connected devices and the HE.
I bought HE because I read so many nice reviews about flawless network and advanced systems.
I am confronting reality though as nothing seems to work. I have had HE for 1 month now. I tried to pair several Zigbee devices with NO success so ever.
So I decided to buy a device that it's recommend either on this forum or it appears in the HE list.
So I bought the gledopto Zigbee 3.0 led controller and was saying to myself that this time it would be fine.
I did as asked. 5 times on off/ factory reset several times but NO pairing at all. I tried all methods of pairing (with no repeaters with clear keys etc) but nothing is discovered.
Is there a specific method we use to pair ? Is it really so difficult ? I wanted to avoir home assistant and use sth more automatic but I get really disappointed and I am asking for your help out there hoping to find a solution.
Thank you so much I'm advance for your help
All the best
Yiannis
Hello Yannis and welcome to Hubitat community forum!
If not done yet, join the Hub owners - Hubitat group so that you are allowed to post screenshots in the forum.
If you go to Settings -> Zigbee details, do you see Zigbee interface enabled and the PAN Ids populated? Have you also tried changing the Zigbee channel (in a case you have strong WiFi interferences)?
What other Zigbee devices you have tried to pair to your HE hub (I suppose it is a C-8 model)?
Can you confirm that when you try to pair a Zigbee device, it is put in a pairing mode - usually, by pressing the pair button for 5 or more seconds. Most of the devices will confirm the pairing mode with a LED flashing.
You can change the channel from the control circled in green, but most probably this is not the problem at the moment (except you have the C-8 antenna put very close to your WiFi router).
However, it is really strange that you have one Zigbee device which is shown crossed out (circled in red). I don't know what does it mean, hopefully someone will chime in and give some more ideas.
As for the deleted device I do not have any idea what it is. I see that I have two devices on the hub, but the only thing that I managed to connect was to connect Alexa with the hub, so every time I pair sth to the hub it will be automatically added to the Alexa network.
Maybe it's that one ?
I send another screenshot with my two devices on the hub.
1st.
You Need to check your WIFI settings and zigbee channel.
Setup your WIFI system to channel ( 1 ) on all routers and AP's and reboot router and AP's.
2nd
Make sure / setup hub ZigBee to channel 20 with 8-12 power.
power off the hub .. using the GUI - Settings / shut down for 3-15 min
Move HUB away from router / ap's using a cat5 cable
3rd
once you have all that setup .. power up hub.
4th
Delete that device ( device )
5th
Now try and add the device you want to the system / make sure you factory default it.
That is a pretty terrible location for a hub. You have it in a metal cage, and there is tons of interfering equipment surrounding it. I would be surprised if you could pair any device with it, or keep devices on the mesh IF they even pair.
Thanks so much for the replies @WarlockWeary & @neonturbo
I did exactly what you told me and I COULD FINALLY PAIR IT !!!
Thank you so much!
Now I am trying to see the interface of the device. I see that i cannot change the colour of the leds. I tried to change the colour map settings and after i clicked save presets. But nothing changed.
Is there another workaround to change the led colour ? I tried as well to change by numbers the hue, level, saturation etc. But each time that i click save presets, i see that nothing has changed. Everything remains like shown below
Current States
colorMode : RGB
colorName : Blue
colorTemperature : 6329
hue : 67
level : 20
saturation : 100
switch : on
I tried as well to switch it on and off but nothing happend
As the problem was probably not the gledopto but my hub's adjustments, I would like to share with you that I just paired another device that could not pair before
It is this one
But same thing. I cannot find the adjustment control. This switch is supposed to switch on and off a wall plug and controls the consumption of electricity. But I do not see anything relative. Not even a switch on/off button.
You may want to start a new thread on this .. sorry I do not know enough to help.
other then you can try a different driver .. just remember if you try a different driver you always have to press the configure button!
Thanks so much for your reply and help @WarlockWeary
I will check it.
By configure button could you please tell me what you mean ? I tried to find more info about this on net but it is not clear to me. Is it a button that I have to create in the interface ?
thanks again enormously!!
