Glass break
The Xiaomi Vibration Sensor is quite good.
It has 3 sensitivity levels, for glass i would recommend set it up on strong as it becomes quite sensitive.
The Sensor also has several states that can be used as triggers (Drop/Tilt/? I forgot one of them).
You might need to get potential the right combination for it to work.
I tested them with the gateway at a friend's place (hence why I order 3 for me and they are in route) not sure how the HE driver is set in HE so it might need tweeking.
Will test everything when HE Hub and the new sensors arrive.
