Ghost Nodes
I am using the C-8 Pro. I have a couple of Ghost Nodes that will not fall off. I have tried removing them in Legacy as well as ZwaveJS. They just stay at pending. Refresh does nothing, deleting does nothing.
I purchased a Zooz 800 z wave stick and the node cannot be removed with Simplicity either. I tried flooding the NOP and immediately clicking Is Failed - nothing. Power down, waited for many minutes. Nothing. Removing power or air gap from neighboring devices. Nothing.
It just will not let me delete it. Any suggestions?
switch to js, shut down and unplug power for 1 full minute. During this time unplug/remove power from the device that made the ghost. Power back up. Wait a couple of mins. Try removing the device now.
I'll try that.
I should note that the device is one that doesn't have power. I am not sure what it is, but it looks like a light switch that I replaced a few years ago.
Were you able to remove your ghost node? I have the same problem with a ghost node, but I don't know which device created this ghost.
Capture d’écran 2026-10-04 234921
Have you tried switching to JS and getting rid of it?
It appeared when I switched to JS...
Have you tried to remove it?
When you press the Refresh button (may take a few times) does the "Remove" button appear?
I've already tried the Refresh button, but even after 20 presses, I never get the Remove button. I thought that after a few days the system would detect the node itself, but after several weeks nothing has changed.
With the new Not Responding detection mecanism, my ghost node was detected and remove button was available to remove it!!! Thanks to Hubitat team! :+1:t2:
