I have a ghost device.... I have tried to discover it...I have tried to refresh it...and I have tried to remove it....Nothing works...
What can I do? What am I missing?
Try powering off the device(s) that come after it in the list. When the โrealโ device has power, it will typically not be removable. And often, a ghost is created when a device didnโt pair properly the first time, and most often, it did end up pairing not to long after when the user retried setting it up.
Problem Solved..... I remove the switches from the Hub...Then I removed the ghost devices....and then I reinstalled the switches....
I then re-ran the mesh review and everything is excellent!!!
Thank you!
