Just at a quick glance, it looks like you need some repeaters to strengthen your Z-Wave Mesh. The LWR RSSI column is a measure of signal strength:
I believe that tha Hubitat antenna has less gain than the SmartThings antenna. Perhaps it’s because of the smaller size. At least that’s what I decided when I came over from SmartThings just over a year ago. I just shrugged my shoulders and sprinkled Repeaters through our house, which improved signal strength. Signals get attenuated / reflected by brick, tile, mirrors, metal appliances, coke vending machine, metal coke signs, etc.
I use the Ring Alarm Range Extender Gen 2 (have 6 of them). They use the Z-Wave Plus 700 series chip and have an internal battery backup. They also send power fail events (switch from mains to battery) to the hub, so you can have a rule to shut down your hub cleanly on power fail (you do have your hub on a UPS, right?).
Seeing this, with all the negative LWR RSSI numbers, I understand better why you are getting the ghosts during pairing.
