Get your SmartThings forever Token now - while supply lasts!
SmartThings plans to severely limit the PAT lifespan from 50 years down to 24 hours. They plan to make the switch at the end of the month, so if you think you might need a token in the future, I would get one now here. (Note: you do need a SmartThings account, but do not need a ST hub.)
Omg. Thanks for warning. I just generated a token for the future.
I am a bit confused.
If I am already using yours integration do I need new token or I am all set?
Assume you are talking about HubiThings Replica? The way I read it, yes if you have a working PAT (token) you should be good going forward as is.
But “I think” after December anyone NEW would NOT be good until after I refactor the application to use the OAuth token for everything. Today it only uses the OAuth token for specific things.
But it’s SmartThings…who knows…
Yes, I have working HubiThings Replica integration.
Thank you for the clarification.
