Generic Zigbee Outlet Power
Hi all
I have a Ledvance Smart+ Plug Zigbee
Configured as Generic Zigbee device.
the power value have only two state 0 o 40
doesen't matter what is connected is a 10W bulb or a 2000W Tumbler...
ah ...sometime switching it off it say 2800...
Is there a solution for this?
If you changed the driver, did you hit "Configure" afterwards? Or even if not, I suppose it wouldn't hurt to hit it once just in case. :slight_smile: (But it should automatically run at pairing if it automatically detected a driver.) I don't have any experience with this specific outlet, but it looks like it is at least supposed to do power metering, so this is the only thing I can think of that might help, besides maybe adjusting your power reporting threshold (1 W is likely higher than you'll really need and I'd recommend doing the least-chatty threshold that still meets your needs, though I understand you're probably trying different values for troubleshooting at the moment, which should be fine).
The threshold have no effect, i have always 0-40.
These devices are not power reporting. Switches only.
OH ... :disappointed:
Suggestion for a power meter plug?
Is ok for High Power devices like tumbler?
It measure low Power like coffe machine too?
My Ariston Is 2000W
I think I will try , thanks .
Truly don’t know the best place for this question. Anyone can feel free to rehome.
I have c-8 hub and Scolmore Click Smart + sockets. Does there happen to be a way to report power consumption of these in dashboard?
