"Generic Z-Wave Switch" driver - no option to export to HomeKit as outlet?
New to Hubitat, coming over from Vera (finally). I had been using a Homebridge plugin to bring my Z-wave devices from Vera to HomeKit, but as soon as Hubitat announced its HomeKit integration I decided to make the jump.
I have probably 60-70 old Jasco/GE switches, dimmers and outlets in my house. I know... I should replace them with newer stuff but they work fine for my needs. Thanks to Lewis's antenna mod every single one of my devices is routed directly to the C-7.
Coming over from Vera I've realized a few things I now need to set up manually:
  1. I need to use the Z-Wave Poller app in order to get status from these old Z-Wave devices
  2. Z-Wave Poller does not offer the option of querying "Generic Z-Wave Outlet" devices
  3. Not only do I have ~15 Z-Wave Outlets (Jasco and Intermatic), I also have a ton of Jasco plug-in Appliance modules, for which Hubitat assigns the "Generic Z-Wave Outlet" driver.
So I pretty quickly realized I needed to change all of those outlets and appliance modules to use the "Generic Z-Wave Switch" driver. That allows me to select them in Z-Wave Poller. Problem solved, at least in terms of getting status on those devices.
However, I notice now in HE's HomeKit app, all of the devices using "Z-Wave Generic Switch" have no option for exporting to HomeKit as a different device type.
I would like for the actual outlet devices to appear in HomeKit as outlets. I know they would if I changed them back to use the Generic Z-Wave Outlet driver, but then I would lose the ability to use them with Z-Wave Poller.
Given that the HomeKit integration is in beta, I hope it can be considered to code in the option to expose devices that use the "Generic Z-Wave Switch" driver as outlets instead of switches. Similar to how it's already possible to export devices that use the "Generic Z-Wave Outlet" driver as switches.
I think I can change each one to show as an outlet from within HomeKit, but given that I have so many of them it would be easier to set it all up from the HE side. That way if I ever need to remove them from HomeKit and add them back I don't have to keep changing them back to outlets.
If this is currently possible and I'm just missing something, please let me know.
This topic was automatically closed 360 days after the last reply. New replies are no longer allowed.
