I would like to suggest the following switch. It can be set to 90 minutes, and will flip on/off at that time. Works every time.
I am not finding on Amazon. Do you happen to have a link?
ALWAYS buy Zooz from here (unless shipping costs tip the scales to Amazon).
Love how the Zooz preview's pricing is always significantly lower than the price after clicking through to the website. ![]()
(Not that it matters to anyone in Canada since they won't ship here.
Why? It appears to be in stock at thesmartesthouse (zooz’s online store) when clicking on the link @TArman just posted.
Ahh I never bought from them. Will check it out thank you
This is kind of interesting, gives you two outlets, separately controlled. ![]()
No info at all at that link.
At least with Zooz, you know what you get:
Strange, works for me.
Goes to the Amazon webpage.
Appears to be a re-badged Zooz. ![]()
Webpage
Minoston 800 Series Z-Wave Plug, Outdoor Zwave Smart Plug with 2 Individual Outlets, Waterproof Z-Wave Smart Outlet for Christmas Lights Compatible with SmartThings, Alexa, Zwave Hub Required (MP24Z)
[4.2 4.2 out of 5 stars ](javascript:void(0)) (1,114)
$33.99$33.99
Get $60 off instantly: Pay $0.00 $33.99 upon approval for the Amazon Store Card. No annual fee.
Style: Outdoor Dual Outlets
- Outdoor Dimmer Outlet
$32.99$32.99
- Outdoor Dual Outlets
$33.99$33.99
- Outdoor Outlet
$31.00$31.00
| Operation Mode | ON-NONE-ON |
| Operating Voltage | 125 Volts (AC) |
| Contact Type | Normally Open |
| Connector Type | Plug In |
| Brand | Minoston |
| Switch Type | Push Button |
| Terminal | Screw |
| Material | Polycarbonate |
| Item dimensions L x W x H | 1.25 x 2.68 x 9.25 inches |
| Circuit Type | 2-way |
[See more](javascript:void(0))
About this item
- [Reliable Z-Wave 800 Series and Support LR] This zwave plug has built-in a 800 series chip. This 800 series zwave plug has better signal coverage than ever, and faster communication, with S2 authenticated security and SmartStart for effortless pairing. Extend the wireless coverage up to 1300ft if your hub supports Long Range
- [Z-Wave Plug with 2 Independently Controlled outlets] This smart plug has 2 outles that can be controlled independently. Enable to rename them and control one of them. Zwave smart outlet uses far less power than Wi-Fi or regular Bluetooth and more flexible and more secure for your data(S2+Smartstar) than Wi-Fi. Its signal can travel through sensors and intervening devices to get where it needs to go
- [Easy to Setup] Less than 1 minute to add this zwave plug to your z-wave hub. Just scan the QR code and press the button 3 times quickly. Plug the home appliances into this zwave plug. This way ordinary appliances can be turned into smart appliances
- [IP65 Rainproof] The IP65 weatherproof of this zwave smart plug ensures that the device can work properly in rainy days. Please hang it vertically to ensure the waterproof function of the casing
- [Intelligent Function] A schedule and timer can be set up and cycle every day. This z-wave plug can remote control with APP and voice control. Enable to set timers for it to turn the device on or off automatically. Saves the energy when plug-in appliances are not needed or accidentally switched on
- [Z-Wave Hub required] This zwave outdoor smart plug is compatible with SmartThings, Vera, Fibaro, Hubitat, and Home Assistant. Work with Alexa and Google Assistant (Z-Wave hub required). CANNOT connect directly with ECHO PLUS! Z-Wave Frequency: 908.42MHz. FCC and ETL listed. NOTE: This zwave outlet is NOT compatible with Honeywell, Ring, ClareHome CLIQ-mini, Vivint
As in, a manual? A lot of palaver. Does it do auto on/auto off?
Zooz & Minoston share an OEM for at least some of their stuff...I have an outdoor plug that is a mirror image of the Zooz and runs perfectly on the Zooz driver. They don't use the same FW...that is company specific AFAIK.
Sorry. ![]()
Price war, lol
If I am understanding you Zooz & Minoston are like one in the same. With that said what do you think about .
Minoston
Smart Plug, Mini Plug-in Z-Wave 800 Series Socket with Built-in Repeater/RangeExtender, Z-Wave Hub Required, Compatible with SmartThings, Wink, Alexa, Google Assistant,FCC Listed, MP21Z
Okay, last question Minoston Smart Plug is $49.78 with tax. And the Zooz is $59.11 + tax. Is the Zooz that much better?
Those Minostons don't do power reporting, in case that would be a feature you'd like.
One more time, 28 bucks plus shipping.
The cart screenshot says 2.
