good but i have to get ahold of them.. have amazon recept. but there is a limit to how many calls and how long i will wait on hold for a 38.00 device..
i have tried the online form now.. no response via email.. will see if it works.
I know what you mean, this stuff should be easy and quick. No need to make it hard for customers.
Luckily I've only had one switch fail and it was the secondary in a 3-way, so didn't even bother to see if it was still under warranty (installed it > five years ago).
i filled out the online form for support and warranty bcasue they wouldnt answer the phone,, and they basically replied i had to call.. as i said a pain in the butt
Thanks for confirming...Not customer-friendly at all. You should be able to provide a receipt and request and it should be taken care of. Just had a warranty repair w/Breville of my espresso maker and all it took was a couple emails and they authorized the repair.
So far, I have replaced 2 Jasco switches and looks like I have 3 more to replace. They just seem to die. At first I thought it was bad power, or lightning that killed the first two. Then a third just stopped working. Now I have fourth and fifth. The first pair are at another physical residence so it isn't just one location. The remote location is still using a Smarthings hub, locally I am using a HE.
Well, here is a kicker. Today being Sunday, I ran to Lowes to see what replacements were available. Nothing that matches my GE 46202 Toggle units. (These were installed a few years ago and I went with toggles to match the other switches.) Loews had Eaton paddle switches. I bought three to fill the box. Got home, HE not working so it was rebooted. I checked the dead switch again and decided to remove it from the system before physically removing it. In doing so, I checked the patio light that has not worked for a few months. According to the dash and log, it just activated. Hmm... Stepped outside to check, sure enough.. it is working.
Back to the entry hall dead switch. When removing the gang of three switches, the neutral jumper popped loose on one that was working. Just to test things, I hold it to a neutral screw toggle the switch and bingo, the dead switch is now alive and working! So, how does a neutral wire sit for at least 4 years then decide to pop loose?
So, two of my thought to be dead GE switches are working again. And, I have 3 Eaton paddle switches for the next project.
I have well over 100 jasco switches/dimmers between my main and vacation house.
Before moving into my current house I have had only 1 of >100 fail. Since moving into this new house I've lost 6-10 in 12 months (some old, some new) all during bad weather.
In my vacation house I've lost 0, ever - all are 3+ years old.
I strongly believe power quality has a lot to do with them dying - either surges or brownouts.
I will say that (so far) I have not lost any of the new style switches/dimmers (quickfit / slim mount), or any of the Motion Dimmer/Switches. It is always the older 14291/14294 switches/dimmers I keep losing.
ya frick the power outages did fry one of my jasco outlets. it is the newer quickfit zwave plus.. cannot find receipt unless it is the honeywell unit that comes saying ge?
So, after finding a loose neutral, I buttoned it all back up only to find the offending switch will not work! I suppose it is bad.
Will proceed with original plan to change out all in the gang box later this week when my wife isn't working in her home office as the breaker controls it too.
We had a power outage a few weeks ago, apparently it took out one of my GE switches, it was a z-wave plus. I called them up and literally within 10 seconds he said, let me send you a new one
No questions asked other than can you send me a pic of the device, you bet
I said, is there any chance it just needs to be reset, he said no, if the blue light is blinking, it's dead
5 mins later I was done with the call and a new switch is in route
