So I have been seeing something weird over the last few weeks since I replaced my C8 with a C8 pro.
My motion sensors seem to be very slow, I have a rule that says turn on the office lights if the sensor sees motion, it does, light comes on, etc. but then the automation doesn't run at all. sometimes up to 1-2 minutes later the light will come on.
It's going to be more helpful to anyone offering help if you state what kind (Zigbee, Z-Wave, or WiFi) motion sensor you own, what brand it is and what's the model number.
Additionally, are you watching the response on the drivers page, or looking at logs? How do you know it's the motion sensor that's slow, and not the lights or the automation that is connecting the two?
Rather than a full repair, might be best to start w/targeted repairs on the office light switch(es) first to see if that helps. Note that the results of repairs can take several days to appear...
@robert2 - can you provide a screen cap of the switch(es) that appear to be lagging, from the Z-Wave Details page, like below:
Also, if you turn the switch(es) on/off from their Device page, are they normally responsive, or also slow to react from that control?
Also...regarding below:
Just wanted to get confirmation that when you looked at your logs when you triggered motion that the motion sensors triggered normaly/fast but the light turned on after a delay.
Should have asked...below happened when you ran a full repair on your entire Z-Wave mesh, via the Repair button at the top of the page, right?
Assuming I have that right... It is Odd to get that failure, you have a nice fast connection on that device. Try running a refresh and then run repair just on node 18.
I am assuming the number of the node is the one in parentheses? or is it the beginning number?
I am seeing a lot of this when I do a repair in the log files:
That's normal when you have Z-Wave issues...the node I'd like you to get a cap of will be 0x18. It likely will be missing routing in the final column...if you have any other mains powered devices that are missing routing in the last column they will also cause problems.
I just redid my entire setup, wiped the hub and added everything back, etc.
Now it is all very quick and runs great again. My C8 Pro setup was a restore from at least two previous hubs, figured why not start from scratch on this.
