I used Claude to update the Enbrighten switch driver. It found a few bugs, patched them, and updated the driver. It also now allows you to set or fetch any parameter if you need to tinker. Install it, push CONFIGURE to update and enjoy. Feel free to copy, update, etc. Hope this helps.
The real reason I did this was that I installed a new switch and the generic driver wouldn't allow me to turn off the LED. Tried tweaking the parameter, failed, so searched, found the driver and updated it with Claude.
Updated to fix device association issue and to add automatic hourly health check (able to be disabled or set to any number of minutes in Preferences) to assure device on/off status is updated in case Hubitat misses a Zwave message.
* GE Enbrighten Z-Wave Plus Switch
* Original driver by Jason Bottjen (Botched1)
* https://raw.githubusercontent.com/Botched1/Hubitat/master/Drivers/GE%20Enbrighten%20Switch/GE%20Enbrighten%20Switch.groovy
* NOTE: The importUrl has intentionally been removed so that "Import" in Hubitat
* does not overwrite these fixes with the original upstream code.
* 1.0.0 (07/16/2019) - Initial Version
* 1.1.0 (07/17/2019) - Removed DoubleTap from BasicSet, added DoubleTap UP/DOWN and TripleTap UP/DOWN as standard buttons 1-4
* 1.2.0 (02/07/2020) - Added pushed, held, and released capability. Required renumbering the buttons. Now 1/2=Up/Down, 3/4=Double Up/Down, 5/6=Triple Up/Down
* 1.2.1 (02/07/2020) - Added doubleTapped events and added doubleTap capability. Now users can use button 3/4 for double tap or the system "doubleTapped" events.
* 1.3.0 (05/17/2020) - Added associations and inverted paddle options
* 2.0.0f (08/13/2020) - Added S2 capability for Hubitat 2.2.3 and newer
* 2.1.0 (08/20/2020) - Fixed some command version issues
* 2.2.0 (08/29/2020) - Added number of button config to configure
* 2.3.0 (02/13/2021) - Added Alternate Exclusion mode to preferences.
* 2.3.1 (03/08/2022) - Added setIndicatorBehavior command. Now users can control LED indicator behavior through custom actions.
* 2.4.0 (10/13/2026) - Patched version:
* - Fixed group 3 association self-repair (commands were built but never sent)
* - Fixed description-logging status message (was reading nonexistent txtEnable setting)
* - Added push(), hold(), release() and doubleTap() commands required by the button capabilities
* - Fixed "Held Down" event text (said "Up held")
* - Lifecycle methods (installed/updated) now send their commands explicitly via sendHubCommand
* - updated() no longer assigns to preference variables; uses local defaults instead
* - configure() now also applies LED / inverted / alternate exclusion parameters and requests firmware version
* - refresh() now queries the parameters this driver actually uses (3, 4, 19)
* - ConfigurationReport now logs readable values and keeps preferences in sync with the device
* - Digital/physical flag now auto-clears after 5 seconds so a missed report can't mislabel the next physical press
* - Central Scene descriptionText no longer claims the switch turned on/off (that comes from the switch report)
* - Removed SmartThings-only "displayed" event option and pointless result list in Central Scene handler
* - Added fingerprints for Jasco in-wall switch product IDs 0x3135, 0x3137 and 0x3238 (device type 0x4952)
* 2.4.1 (10/13/2026) - Corrected fingerprint comments to the actual models (per the Z-Wave JS device database):
* 0x3135 = GE/Enbrighten 46201 paddle, 0x3137 = GE/Enbrighten 46202 toggle, 0x3238 = UltraPro 39354/54912 toggle
* - "Inverted" preference now notes it is only documented for the 46202 (parameter 4)
* - Added setParameter command (parameter number, size in bytes, value) and getParameter command
* - Configuration reports for parameters other than 3/4/19 are now logged at info level so results are visible
* 2.5.0 (10/20/2026) - Fixed infinite group 3 association repair loop: the hub check compared Short node IDs to an
* Integer hub ID with List.contains(), which is never true. Now compares numerically and gives up
* after 3 attempts (counter resets on Refresh / Configure)
* - Added periodic status polling: "Status poll interval (minutes)", 0 = disabled, 1-1440, default 60 (hourly).
* Polling restarts on save, configure, install and hub reboot (Initialize capability)
* 2.5.1 (10/20/2026) - First poll after a reboot, save, configure or install is now at a random point within one
* interval (minimum 30 seconds) so multiple devices don't all poll at the same time
import groovy.transform.Field
@Field static Map commandClassVersions =
0x20: 1 // Basic
,0x25: 1 // Switch Binary
,0x5B: 1 // Central Scene
,0x6C: 1 // Supervision
,0x70: 2 // Configuration
,0x72: 2 // Manufacturer Specific
,0x85: 2 // Association
,0x86: 3 // Version
@Field static Map ledOptions = [
"0": "LED ON When Switch OFF",
"1": "LED ON When Switch ON",
"2": "LED Always OFF",
"3": "LED Always ON"
@Field static final Integer DEFAULT_POLL_MINUTES = 60
@Field static final Integer MAX_POLL_MINUTES = 1440 // minutes in a day
@Field static final Integer MAX_GROUP3_RETRIES = 3
metadata {
definition (name: "GE Enbrighten Z-Wave Plus Switch", namespace: "Botched1", author: "Jason Bottjen") {
capability "Actuator"
capability "DoubleTapableButton"
capability "HoldableButton"
capability "PushableButton"
capability "ReleasableButton"
capability "Configuration"
capability "Initialize"
capability "Refresh"
capability "Sensor"
capability "Switch"
capability "Light"
command "setIndicatorBehavior", [[name: "LED Indicator Behavior", type: "ENUM", description: "", constraints: ["LED ON When Switch OFF", "LED ON When Switch ON", "LED Always OFF", "LED Always ON", "0", "1", "2", "3"]]]
command "setParameter", [
[name: "Parameter Number*", type: "NUMBER", description: "Configuration parameter number (1-255)"],
[name: "Size (bytes)*", type: "ENUM", description: "Parameter length in bytes", constraints: ["1", "2", "4"]],
[name: "Value*", type: "NUMBER", description: "Value to set (fits within the chosen size)"]
command "getParameter", [
[name: "Parameter Number*", type: "NUMBER", description: "Configuration parameter number (1-255); the result appears in the logs"]
// Jasco in-wall on/off switches (manufacturer 0x0063, product type 0x4952), per the Z-Wave JS device database
fingerprint mfr: "0063", prod: "4952", deviceId: "3135", deviceJoinName: "GE Enbrighten Z-Wave Plus Switch" // GE/Enbrighten 46201 / ZW4008 paddle, 500 series
fingerprint mfr: "0063", prod: "4952", deviceId: "3137", deviceJoinName: "GE Enbrighten Z-Wave Plus Switch" // GE/Enbrighten 46202 / ZW4009 toggle, 500 series
fingerprint mfr: "0063", prod: "4952", deviceId: "3238", deviceJoinName: "UltraPro Z-Wave Plus Switch" // UltraPro 39354 / 54912 / ZW4009 toggle, 500 series
preferences {
input name: "paramLED", type: "enum", title: "LED Indicator Behavior", multiple: false, options: ["0": "LED ON When Switch OFF (default)", "1": "LED ON When Switch ON", "2": "LED Always OFF", "3": "LED Always ON"], required: false, displayDuringSetup: true
input name: "paramInverted", type: "enum", title: "Switch Buttons Direction (parameter 4; documented for GE 46202 only, likely ignored on UltraPro 39354)", multiple: false, options: ["0": "Normal (default)", "1": "Inverted"], required: false, displayDuringSetup: true
input name: "paramAlternateExclusion", type: "enum", title: "Enable alternate exclusion (2-ON, 2-OFF). NOTE: Turning this ON can make device report status faster (firmware bug?)!", multiple: false, options: ["0": "OFF (default)", "1": "ON"], required: false, displayDuringSetup: true
input name: "pollInterval", type: "number", title: "Status poll interval (minutes, 0 = disabled, max 1440)", description: "How often to ask the switch for its on/off state. Default 60 (once an hour).", range: "0..1440", defaultValue: 60, required: false
input name: "requestedGroup2", type: "text", title: "Association Group 2 Members (hex node IDs, comma separated, max of 5):", required: false
input name: "requestedGroup3", type: "text", title: "Association Group 3 Members (hex node IDs, comma separated, max of 4):", required: false
input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: false
input name: "logDesc", type: "bool", title: "Enable descriptionText logging", defaultValue: true
// Parse
void parse(String description) {
if (logEnable) log.debug "parse description: ${description}"
hubitat.zwave.Command cmd = zwave.parse(description, commandClassVersions)
if (cmd) {
zwaveEvent(cmd)
// Helpers
String secure(String cmd) {
return zwaveSecureEncap(cmd)
String secure(hubitat.zwave.Command cmd) {
// Sends a list of formatted Z-Wave commands from places where a returned list is NOT
// automatically sent by the hub (event handlers, installed(), updated(), scheduled jobs).
void sendCommands(List<String> cmds, Integer delay = 250) {
if (!cmds) return
sendHubCommand(new hubitat.device.HubMultiAction(delayBetween(cmds, delay), hubitat.device.Protocol.ZWAVE))
private String settingOrDefault(String name, String defaultValue) {
def value = settings[name]
return (value == null || value.toString() == "") ? defaultValue : value.toString()
// Status polling
private Integer pollMinutes() {
def value = settings.pollInterval
if (value == null || value.toString() == "") return DEFAULT_POLL_MINUTES
Integer minutes
try {
minutes = new BigDecimal(value.toString()).intValue()
} catch (Exception e) {
log.warn "${device.displayName}: invalid poll interval '${value}', using ${DEFAULT_POLL_MINUTES} minute(s)"
return Math.max(0, Math.min(MAX_POLL_MINUTES, minutes))
// Schedules the next poll. With randomStart, the first poll lands at a random point within one
// interval (minimum 30 seconds), so devices restarted together (e.g. after a hub reboot) don't
// all poll at the same moment. Later polls keep the fixed interval, so they stay staggered.
// Returns the delay in seconds, or 0 if polling is disabled.
private Integer schedulePoll(Boolean randomStart = false) {
unschedule("poll")
Integer minutes = pollMinutes()
if (minutes <= 0) return 0
Integer seconds = minutes * 60
if (randomStart) {
seconds = 30 + new Random().nextInt(seconds)
runIn(seconds, "poll")
return seconds
private void startPolling() {
Integer seconds = schedulePoll(true)
if (seconds > 0) {
log.info "${device.displayName}: status polling every ${pollMinutes()} minute(s), first poll in ${seconds} seconds"
} else {
log.info "${device.displayName}: status polling disabled"
// Scheduled job: asks the switch for its current on/off state, then schedules the next poll.
void poll() {
if (logEnable) log.debug "${device.displayName}: polling switch status"
schedulePoll()
sendCommands([secure(zwave.switchBinaryV1.switchBinaryGet().format())])
// Z-Wave Messages
void zwaveEvent(hubitat.zwave.commands.supervisionv1.SupervisionGet cmd) {
hubitat.zwave.Command encapCmd = cmd.encapsulatedCommand(commandClassVersions)
if (encapCmd) {
zwaveEvent(encapCmd)
sendHubCommand(new hubitat.device.HubAction(secure(zwave.supervisionV1.supervisionReport(sessionID: cmd.sessionID, reserved: 0, moreStatusUpdates: false, status: 0xFF, duration: 0)), hubitat.device.Protocol.ZWAVE))
void zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
if (logEnable) log.debug "---BASIC REPORT V1--- ${device.displayName} sent ${cmd} (ignored; switch state comes from Switch Binary reports)"
void zwaveEvent(hubitat.zwave.commands.basicv1.BasicSet cmd) {
if (logEnable) log.debug "---BASIC SET V1--- ${device.displayName} sent ${cmd} (ignored; taps come from Central Scene notifications)"
void zwaveEvent(hubitat.zwave.commands.associationv2.AssociationReport cmd) {
if (logEnable) log.debug "---ASSOCIATION REPORT V2--- ${device.displayName} sent groupingIdentifier: ${cmd.groupingIdentifier} maxNodesSupported: ${cmd.maxNodesSupported} nodeId: ${cmd.nodeId} reportsToFollow: ${cmd.reportsToFollow}"
if (cmd.groupingIdentifier != 3) return
// Compare numerically: nodeId entries are Shorts, zwaveHubNodeId is an Integer,
// so List.contains() would never match.
Integer hub = zwaveHubNodeId as Integer
Boolean hubPresent = cmd.nodeId?.any { (it as Integer) == hub }
if (hubPresent) {
state.group3Retries = 0
sendEvent(name: "numberOfButtons", value: 6)
return
Integer tries = (state.group3Retries ?: 0) as Integer
if (tries >= MAX_GROUP3_RETRIES) {
log.error "${device.displayName}: hub still not in association group 3 after ${tries} attempts, giving up. Group 3 members reported: ${cmd.nodeId}"
sendEvent(name: "numberOfButtons", value: 0)
return
state.group3Retries = tries + 1
log.warn "${device.displayName}: hub is not in association group 3 (members: ${cmd.nodeId}), re-adding it (attempt ${tries + 1} of ${MAX_GROUP3_RETRIES})"
sendCommands([
secure(zwave.associationV2.associationSet(groupingIdentifier: 3, nodeId: zwaveHubNodeId).format()),
secure(zwave.associationV2.associationGet(groupingIdentifier: 3).format())
], 500)
void zwaveEvent(hubitat.zwave.commands.configurationv2.ConfigurationReport cmd) {
if (logEnable) log.debug "---CONFIGURATION REPORT V2--- ${device.displayName} sent ${cmd}"
Integer value = cmd.scaledConfigurationValue
switch (cmd.parameterNumber) {
case 3:
if (logDesc) log.info "${device.displayName} LED indicator: ${ledOptions[value.toString()] ?: value}"
device.updateSetting("paramLED", [type: "enum", value: value.toString()])
break
case 4:
if (logDesc) log.info "${device.displayName} paddle direction: ${value == 1 ? 'Inverted' : 'Normal'}"
device.updateSetting("paramInverted", [type: "enum", value: value.toString()])
break
case 19:
if (logDesc) log.info "${device.displayName} alternate exclusion: ${value == 1 ? 'ON' : 'OFF'}"
device.updateSetting("paramAlternateExclusion", [type: "enum", value: value.toString()])
break
default:
log.info "${device.displayName} parameter ${cmd.parameterNumber} (size ${cmd.size}) = ${value}"
void zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
if (logEnable) log.debug "---BINARY SWITCH REPORT V1--- ${device.displayName} sent ${cmd}"
// If a command was sent from the hub in the last few seconds, treat this report as digital
String newType = state.bin ? "digital" : "physical"
state.bin = false
unschedule("clearDigitalFlag")
String newValue = cmd.value ? "on" : "off"
String curValue = device.currentValue("switch")
if (curValue != newValue) {
String desc = "${device.displayName} was turned ${newValue} [${newType}]"
if (logDesc) log.info desc
sendEvent(name: "switch", value: newValue, descriptionText: desc, type: newType, isStateChange: true)
void zwaveEvent(hubitat.zwave.commands.versionv3.VersionReport cmd) {
String fw = "${cmd.applicationVersion}.${cmd.applicationSubVersion}"
device.updateDataValue("firmwareVersion", fw)
if (logEnable) log.debug "---VERSION REPORT V3--- ${device.displayName} is running firmware version: ${fw}, Z-Wave version: ${cmd.zWaveProtocolVersion}.${cmd.zWaveProtocolSubVersion}"
void zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
if (logEnable) log.debug "Hail command received (ignored)"
void zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.DeviceSpecificReport cmd) {
if (logEnable) log.debug "Device Specific Report: ${cmd}"
if (cmd.deviceIdType == 1) {
String serialNumber = ""
if (cmd.deviceIdDataFormat == 1) {
cmd.deviceIdData.each { serialNumber += hubitat.helper.HexUtils.integerToHexString(it & 0xff, 1).padLeft(2, '0') }
} else {
cmd.deviceIdData.each { serialNumber += (char) it }
device.updateDataValue("serialNumber", serialNumber)
void zwaveEvent(hubitat.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
if (logEnable) log.debug "CentralSceneNotification: sceneNumber ${cmd.sceneNumber}, keyAttributes ${cmd.keyAttributes}"
Integer scene = cmd.sceneNumber as Integer // 1 = Up/top, 2 = Down/bottom
if (scene != 1 && scene != 2) return
String dir = scene == 1 ? "Up" : "Down"
switch (cmd.keyAttributes as Integer) {
case 0: // single press
buttonEvent("pushed", scene, "${dir} Pushed (button ${scene})", "physical")
break
case 1: // released after hold
buttonEvent("released", scene, "${dir} Released (button ${scene})", "physical")
break
case 2: // held
buttonEvent("held", scene, "${dir} Held (button ${scene})", "physical")
break
case 3: // double tap -> buttons 3 (up) / 4 (down)
buttonEvent("pushed", scene + 2, "Doubletap ${dir.toLowerCase()} (button ${scene + 2})", "physical")
buttonEvent("doubleTapped", scene, "Doubletap ${dir.toLowerCase()} (doubleTapped ${scene})", "physical", false)
break
case 4: // triple tap -> buttons 5 (up) / 6 (down)
buttonEvent("pushed", scene + 4, "Tripletap ${dir.toLowerCase()} (button ${scene + 4})", "physical")
break
default:
if (logEnable) log.debug "Unhandled keyAttributes ${cmd.keyAttributes} (e.g. 4x/5x tap)"
private void buttonEvent(String name, Integer button, String what, String type, Boolean logIt = true) {
String desc = "${device.displayName} had ${what} [${type}]"
if (logIt && logDesc) log.info desc
sendEvent(name: name, value: button, descriptionText: desc, type: type, isStateChange: true)
void zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "${device.displayName} received unhandled command: ${cmd}"
// Driver Commands
def on() {
if (logEnable) log.debug "Turn device ON"
markDigital()
return [secure(zwave.switchBinaryV1.switchBinarySet(switchValue: 0xFF).format())]
def off() {
if (logEnable) log.debug "Turn device OFF"
markDigital()
return [secure(zwave.switchBinaryV1.switchBinarySet(switchValue: 0x00).format())]
private void markDigital() {
state.bin = true
runIn(5, "clearDigitalFlag")
void clearDigitalFlag() {
state.bin = false
// Button capability commands (virtual presses from the device page, dashboards or rules)
void push(button) {
buttonEvent("pushed", button as Integer, "button ${button} pushed", "digital")
void hold(button) {
buttonEvent("held", button as Integer, "button ${button} held", "digital")
void release(button) {
buttonEvent("released", button as Integer, "button ${button} released", "digital")
void doubleTap(button) {
buttonEvent("doubleTapped", button as Integer, "button ${button} double-tapped", "digital")
def refresh() {
log.info "refresh() called"
return delayBetween([
secure(zwave.switchBinaryV1.switchBinaryGet().format()),
secure(zwave.configurationV2.configurationGet(parameterNumber: 3).format()),
secure(zwave.configurationV2.configurationGet(parameterNumber: 4).format()),
secure(zwave.configurationV2.configurationGet(parameterNumber: 19).format()),
], 250)
void installed() {
log.info "installed..."
sendCommands(configureCmds())
startPolling()
// Called by the hub at startup (Initialize capability) so polling resumes after a reboot
void initialize() {
log.info "initialize..."
startPolling()
void updated() {
log.info "updated..."
log.warn "debug logging is: ${logEnable == true}"
log.warn "description logging is: ${logDesc == true}"
unschedule("logsOff")
if (logEnable) runIn(1800, "logsOff")
startPolling()
if (state.lastUpdated && now() <= state.lastUpdated + 3000) return
state.lastUpdated = now()
sendCommands(associationCmds() + parameterCmds())
def configure() {
log.info "configure triggered"
startPolling()
return delayBetween(configureCmds(), 250)
private List<String> configureCmds() {
state.bin = false
List<String> cmds = associationCmds() + parameterCmds()
cmds << secure(zwave.versionV3.versionGet().format())
cmds << secure(zwave.switchBinaryV1.switchBinaryGet().format())
return cmds
private List<String> associationCmds() {
List<String> cmds = []
// Group 1: lifeline
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier: 1, nodeId: zwaveHubNodeId).format())
// Group 2: local load (user-specified devices only)
List nodes = parseAssocGroupList(settings.requestedGroup2, 2)
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier: 2, nodeId: []).format())
if (nodes) cmds << secure(zwave.associationV2.associationSet(groupingIdentifier: 2, nodeId: nodes).format())
cmds << secure(zwave.associationV2.associationGet(groupingIdentifier: 2).format())
state.currentGroup2 = settings.requestedGroup2
// Group 3: double tap / scenes (always includes the hub)
nodes = parseAssocGroupList(settings.requestedGroup3, 3)
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier: 3, nodeId: []).format())
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier: 3, nodeId: nodes).format())
cmds << secure(zwave.associationV2.associationGet(groupingIdentifier: 3).format())
state.currentGroup3 = settings.requestedGroup3
return cmds
private List<String> parameterCmds() {
Integer led = settingOrDefault("paramLED", "0").toInteger()
Integer inverted = settingOrDefault("paramInverted", "0").toInteger()
Integer altExcl = settingOrDefault("paramAlternateExclusion", "0").toInteger()
return [
secure(zwave.configurationV2.configurationSet(scaledConfigurationValue: led, parameterNumber: 3, size: 1).format()),
secure(zwave.configurationV2.configurationSet(scaledConfigurationValue: inverted, parameterNumber: 4, size: 1).format()),
secure(zwave.configurationV2.configurationSet(scaledConfigurationValue: altExcl, parameterNumber: 19, size: 1).format()),
def setIndicatorBehavior(param) {
log.info "setting indicator behavior to ${param}"
Integer paramValue
switch (param) {
case "LED ON When Switch OFF": paramValue = 0; break
case "LED ON When Switch ON": paramValue = 1; break
case "LED Always OFF": paramValue = 2; break
case "LED Always ON": paramValue = 3; break
case "0": case "1": case "2": case "3":
paramValue = param.toInteger()
break
default:
log.warn "setIndicatorBehavior: unknown value '${param}', ignoring"
return
device.updateSetting("paramLED", [type: "enum", value: paramValue.toString()])
secure(zwave.configurationV2.configurationSet(scaledConfigurationValue: paramValue, parameterNumber: 3, size: 1).format()),
], 250)
// Set any configuration parameter by number, size (1, 2 or 4 bytes) and value.
// Values above the signed range for the size (e.g. 200 for 1 byte) are sent as the equivalent
// unsigned bit pattern, so both signed and unsigned values can be entered.
def setParameter(paramNum, size, value) {
Integer p
Integer s
Long v
try {
p = new BigDecimal(paramNum.toString()).intValueExact()
s = size.toString().toInteger()
v = new BigDecimal(value.toString()).longValueExact()
log.warn "setParameter: invalid input (parameter: ${paramNum}, size: ${size}, value: ${value}); use whole numbers"
return
if (p < 1 || p > 255) {
log.warn "setParameter: parameter number ${p} is out of range (1-255)"
return
if (!(s in [1, 2, 4])) {
log.warn "setParameter: size ${s} is invalid; must be 1, 2 or 4 bytes"
return
Long signedMin = -(1L << (8 * s - 1))
Long signedMax = (1L << (8 * s - 1)) - 1
Long unsignedMax = (1L << (8 * s)) - 1
if (v < signedMin || v > unsignedMax) {
log.warn "setParameter: value ${v} does not fit in ${s} byte(s) (allowed ${signedMin} to ${unsignedMax})"
return
// Convert unsigned values above the signed max into their two's-complement equivalent
Integer scaled = (v > signedMax ? v - (1L << (8 * s)) : v) as Integer
log.info "${device.displayName}: setting parameter ${p} (size ${s}) to ${v}"
secure(zwave.configurationV2.configurationSet(scaledConfigurationValue: scaled, parameterNumber: p, size: s).format()),
secure(zwave.configurationV2.configurationGet(parameterNumber: p).format())
], 500)
def getParameter(paramNum) {
Integer p
try {
log.warn "getParameter: invalid parameter number '${paramNum}'"
return
log.warn "getParameter: parameter number ${p} is out of range (1-255)"
return
log.info "${device.displayName}: requesting parameter ${p}"
return [secure(zwave.configurationV2.configurationGet(parameterNumber: p).format())]
private List parseAssocGroupList(list, group) {
List nodes = group == 2 ? [] : [zwaveHubNodeId]
if (list) {
def nodeList = list.split(',')
Integer max = group == 2 ? 5 : 4
Integer count = 0
nodeList.each { node ->
node = node.trim()
if (count >= max) {
log.warn "Association Group ${group}: Too many members. Greater than ${max}! This one was discarded: ${node}"
} else if (node.matches("\\p{XDigit}+")) {
Integer nodeId = Integer.parseInt(node, 16)
if (nodeId == zwaveHubNodeId) {
log.warn "Association Group ${group}: Adding the hub ID as an association is not allowed."
} else if (nodeId > 0 && nodeId < 256) {
nodes << nodeId
count++
} else {
log.warn "Association Group ${group}: Invalid member: ${node}"
} else {
if (logEnable) log.debug "Group ${group} nodes: ${nodes}"
return nodes
void logsOff() {
log.warn "debug logging disabled..."
device.updateSetting("logEnable", [value: "false", type: "bool"])
