Does anyone know if the GE/Jasco/Enbrighten outlets support power monitoring? And if so, if there's a driver available that supports it? Everything I found in here discusses just using the generic driver which does not seem to have that as a attribute.
The generic outlet driver supports power reporting if it's supported on the device.
if powerCluster: none is shown in the driver data section, then the device doesn't support power reporting.
At least the z-wave versions do not.
Don't know about the zigbee versions.
Here is the Data Device stuff for the zigbee version:
I assume from the word "powerCluster: none", that it doesn't do power reporting.
Hrmm .. Guess is seems that way. Thought that was built into that one SiLabs chip that literally every zwave device is based on... It's like a sense resistor that costs two tenths of a penny to hook up the pin.. Apparently two tenths of a cent too much
features like this really have nothing to do with the radio module and everything to do with external circuitry.
that is correct, this one doesn't report power.
