Hi.
Question on this please.
My linear garage door opener has acted up a few times and i'm planning on ripping it out the next time it glitches and installing a ZEN 16.
I do have a couple of questions though please on your app.
I have a linear / go control garage door opener that i bought form Lowes when i had an IRIS platform.
When i installed it on Hubitat i'm using a generic Zwave Garage door opener
With the linear door opener, the tilt sensor ties directly to the opener - not back to the hub...at least i believe it does as i don't have any tilt sensors as devices on my setup.
Does your app require the use of a tilt sensor or contact sensor to confirm open / closed states? -
Uncertain if this will operate any differently...but would like to ask. On my dashboard, a green tile represents closed, a red tile represents open.
- When i call for the door to open, my dashboard will go to a grey state and the text in the tile updates to "opening" Once open, the tile turns red and updates the state as "open"
- when i call for the door to close, the tile will once again go to a grey state, update the text as "closing" , then when closed, the tile turns green and the text will then say "closed"
Does all of that work the same way when using the Zen 16 as a garage door opener? easy enough to use the App when inside the home but if i want to open the door when off the network im presuming i will still have to use the dashboard.
Lastly...and this isn't a big thing. I note in the ZEN 16 instructions for using it as a garage door that a siren can be connected to the zen to alert people on a change of door state. With the linear door controller, it beeps a few seconds before it starts moving. Is that something this can do too? having a little advanced warning is beneficial if it closes automatically and someone or something is in the way
Mac
